how much boost can i run almost stock b16?
i have a mr. gasket head gasket, arp head studs, block guard, stock over-bore pistons 81.25mm, rc 440 injectors, walbaro 255lph fuel pump, vafc/avc-r , skunk2 intake manifold, cam gears, apex n1, and a sohc greddy turbo kit modded to fit my 99 si. i'm running 10 lbs now. what would be the most i could run?
Guest
Posts: n/a
Re: how much boost can i run almost stock b16? (Acura_I-RS)
Stock map sensor is only good to ~11psi, so unless you have a 3 bar or somethign tricking yours then that is all you can boost...anyways a stock b16a can handle more power than that turbo can make, it loses efficentcy @13-14psi on a sohc.
Boostless97Lude
02-14-2003 06:39 PM
FUP23
02-10-2002 06:46 PM
