Jim Fab Bars mounting question.
Old Sep 19, 2003 | 06:41 AM
underpressure02's Avatar
Default Jim Fab Bars mounting question.
I got a set of the jim fab bars and when I went to mount the cross bar I found that two of the nuts that should be welded in on the sub frame are missing. I was going to tap the holes and use a larger bolt to bolt the car up. My question is this... Once I bolt the bar up can I then weld it to the sub frame for added security and strength? I was looking at it last night and it appears that the only thing that needs to pivot is the two bars that attach to the LCA.
Old Sep 19, 2003 | 06:50 AM
Overblown-Teg's Avatar
Default Re: Jim Fab Bars mounting question. (underpressure02)
You want to weld the brackets that go where the tow hooks used to be? Can you see that it would ever get in the way? You shouldn't have to take anything through there so it should be fine to weld them in solid.
Old Sep 19, 2003 | 06:59 AM
Default Re: Jim Fab Bars mounting question. (Overblown-Teg)
Yes I would like to bolt them where the tow hooks use to be then weld them since two of the holes are missing the nuts behind them. The person who had the car before had z10's on it and must have broken the welds off the nuts. I just do not feel safe taping that metal and having the bar held in with a bolt. So I figured if I welded it that would make it safer, but was not sure if that bar needed to be able to flex at all.
Old Sep 19, 2003 | 07:05 AM
No welding it should work very well. When did you get your new civic? last I saw you were still looking for one.
Old Sep 19, 2003 | 10:20 AM
Also does anyone know how to set the preload on the tracion bars? I did a search and everyone is saying start them off at Zero preload then adjust them from there. How do you know how much to adjust them to? Is there such a thing as to much preload?
jonesEK
Aug 25, 2010 08:28 AM
JDM-KIDD
Apr 29, 2010 10:54 AM
Skipper75
Suspension & Brakes
May 14, 2007 11:08 AM
Viorent Grip! EG
Sep 10, 2003 02:06 AM
SPiFF
Jul 3, 2001 03:37 AM
