to post or blockgaurd
12-14 psi on a stock y8 block...zdyne gold...post it or blockgaurd
im leaning towards posting it
thanks
if posted with zdyne, how high can i boost on the b16/supra piston setup(~8.2:1 comp)
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 »</TD></TR><TR><TD CLASS="quote">12-14 psi on a stock y8 block...zdyne gold...post it or blockgaurd
thanks
if posted with zdyne, how high can i boost on the b16/supra piston setup(~8.2:1 comp)</TD></TR></TABLE>
either way you must bore/hone it, its your call
thanks
ive heard posting is a bit better, and i can do it myself. I kno neither really do much, its that whole piece of mind thing lol
instead of building my boost level around my setup..im building my setup around the boost level..good idea??
Go with the posting. Its 36.00 for the parts from ENDYN, and takes about an hour to do. It will support the top, and middle of the cylinders, unlike a block guard that only supports the top. I have done it abotu 5 times, and its so easy, its not even funny.
http://www.muller.net/sonny/crx/engine/posted.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinatenexus »</TD></TR><TR><TD CLASS="quote">Go with the posting. Its 36.00 for the parts from ENDYN, and takes about an hour to do. It will support the top, and middle of the cylinders, unlike a block guard that only supports the top. I have done it abotu 5 times, and its so easy, its not even funny.
What was used to seal the posts on that block?
I've lived with blockguards in my D16Y8 turbo, and B18C turbo - pushed over 1.7 bar on the D16Y8 a couple times (with my hybrid piston/rod package) and didn't have a problem
Mine were TIg welded in place,, but I am sure there is some type of aluminum epoxy that will work just fine. go to the forums on the Endyne homw page,, I thike there is a thread about it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 »</TD></TR><TR><TD CLASS="quote">if posted with zdyne, how high can i boost on the b16/supra piston setup(~8.2:1 comp)</TD></TR></TABLE>
If tuned right, you can push around 18psi safely on a daily basis.. you can go higher, but its at your own risk. I've boosted very high in the past, and the rods/pistons seemed to be able to handle the power (though its not something that I did on a regular basis)
You do know any one with a band saw can make the post. They are just bar stock aluminum thats threaded. All you do is cut it to the size you want, and cut a slot in the end so you can tighten them with a flat head screw driver. Get a couple in on the deal, and I can supply them far cheaper than anybody else,,,
Bump for a great post that i've been debating myself. I've been kinda leary about posting my block. It's kinda new to me and I don't want to **** up my LS. How much does it help??
So 18psi daily on a posted block, would that be the same for a D16Y8 block with let's say uh, 9:1 CP pistons, Eagle Rods, Blockguard and Hondata? Would it be a certain psi or a certain HP rating?
one way to find out,,,lol. I remember reading somewhere that if properly stabulized the D series sleeves could be pushed to 18 PSi,,,,, but I don't remember where I saw that
i've pushed well over 18psi on my stock d16y8 sleeves (only blockguard to help support them) and i had no problems at all. Blockguards get their bad name from those who don't have them installed properly, and for those who don't have the blockguard water holes lined up with the holes on the headgasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus »</TD></TR><TR><TD CLASS="quote">
either way you must bore/hone it, its your call</TD></TR></TABLE>
why would he have to bore?
