Anyone using a techedge 1.5 and AEM EMS?
I just got my techedge back from australia (sent it in for some clean up work) and I hooked it all up with the ems and the display, and they both give me different readings. They're not way off, but the aem will read around 2 afr points higher then the techedge display. I have the ems set correctly to what the NTK gives out, but I'm not sure if the display was calibrated after leaving techedge (Still waiting for an email to see if it was calibrated).
I'm just wondering, since they both show different numbers, which would you take as correct? I'm bent on taking the values the ems is giving me, since I know that the voltages in the graph are correct, and I don't know about the display.
Just curious if anyone else had this happen to them..
Re: Anyone using a techedge 1.5 and AEM EMS? (Canuk_SiR)
nope, your a moron
thats weird though. they probably didnt calibrate the display.
are you sure that values in the ems are right??
