thinkign of turbo
Old Sep 17, 2003 | 07:21 PM
Nader_D's Avatar
Default thinkign of turbo
hey, i got a d15z1 (vx motor, believe thats the right code) so far if i want to turbo my motor, i have the turbo, injectors and a shitty *** intercooler (doing home-made turob style) i know i need the following:
-oil lines, piping, a better intercooler, bov/wastegate, i have the proper manifold, what else will i need? thanks
ps; would you turob my motor?
Old Sep 17, 2003 | 07:38 PM
Nader_D's Avatar
Default Re: thinking of turbo (Nader_D)
bump? anyone?
Old Sep 17, 2003 | 07:45 PM
kevinoneill's Avatar
Bump
You might want to specify what type of Turbo, and type of "shitty *** intercooler".
tommyten's Avatar
hell, why not, DO IT!!!
Old Sep 17, 2003 | 08:30 PM
KillerBee18's Avatar
Default Re: thinkign of turbo (Nader_D)
if you got the turbo and IC then why waste it
Old Sep 17, 2003 | 08:35 PM
B94Cast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nader_D &raquo;</TD></TR><TR><TD CLASS="quote">hey, i got a d15z1 (vx motor, believe thats the right code) so far if i want to turbo my motor, i have the turbo, injectors and a shitty *** intercooler (doing home-made turob style) i know i need the following:
I would say: Boost what you can safely, add on later, but boost!
You have the turbo, injectors, manifold, IC, do you have an AFC/V-AFC? If so, run the afc hack on low boost with a BOV/Waste combo off of ebay. Stay with what you have. No reason to get another IC at this stage in the game. Spend the money on the BOV/Waste, get boosted, and slowly start replacing parts and tuning as is necessary. If you wait until you have the perfect setup, then you will probably be waiting forever. Just play it safe, boost a bit and tune at each stage!
My 2 coppers at any rate
Best of luck!
Old Sep 18, 2003 | 05:37 PM
Nader_D's Avatar
Default Re: thinkign of turbo (B94Cast)
do i need to get v-afc? since i need vtec version?
or is there another way around it?
holsetcivic
Jun 13, 2009 10:35 AM
benclimber17
Feb 25, 2008 10:59 AM
ktek3
Aug 15, 2007 10:09 AM
accordking
Aug 25, 2003 06:22 AM
EGlovr
Jun 24, 2002 08:00 AM
