dyno tuned (chart inside)
Old Sep 18, 2003 | 02:31 PM
graphic's Avatar
Default dyno tuned (chart inside)
this is a 98 prelude running a f-max kit
at a non steady 5 psi intercooled
first run..i got 144whp w/ boost retard at 1 deg per psi...
and these are the final 2 runs...non retard and tuned the mf2 a little
i can't figure out why i am making such shitty numbers...i checked timing,exhuast blockage, leaks, and even did a compression check...
everything was fine...but somehow i am missing like 30whp
pics here
http://www.geocities.com/stickupman2000/
Modified by graphic at 7:18 AM 9/20/2003
Old Sep 18, 2003 | 04:34 PM
b16ahybrid's Avatar
Default Re: dyno tuned (graphic)
30hp more like about 50hp....
what are you tuning with?
Old Sep 18, 2003 | 04:51 PM
graphic's Avatar
Default Re: dyno tuned (b16ahybrid)
a wide- band o2 sensor don't know which...he clipped it in my exhaust pipe's tip and that is all i know about
Old Sep 19, 2003 | 06:09 AM
b16ahybrid's Avatar
Fmu, hondata,v-afc,etc ? which form of fuel delivery
Old Sep 19, 2003 | 10:59 AM
graphic's Avatar
erl mf2 w/ 2 additional 440 cc injectors
Old Sep 19, 2003 | 11:02 AM
InTeGrA B18b1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graphic &raquo;</TD></TR><TR><TD CLASS="quote">erl mf2 w/ 2 additional 440 cc injectors</TD></TR></TABLE>
i dont understand you have 6 injectors?
FuzzyGreen's Avatar
imagestation account is password protected.
This sounds like another example of prelude motors not making power with boost. Do a search and you will find many reports similar to this one.
Old Sep 19, 2003 | 11:10 AM
graphic's Avatar
Default Re: dyno tuned (FuzzyGreen)
yeah i got 6...4 stock and 2 additional mounted on charge pipe
know any site i can host my dyno at...
it shows 180.3whp and 156.5 wtq at 5 psi
Old Sep 19, 2003 | 12:34 PM
ChargedLude97's Avatar
Quick question is this a sport shift?? That would explain a little bit why the numbers are so low.
Old Sep 19, 2003 | 01:25 PM
graphic's Avatar
Default Re: (ChargedLude97)
no it is a manual
Old Sep 19, 2003 | 10:08 PM
Ri5e's Avatar
Default Re: (graphic)
Numbers are lower than stock
Old Sep 19, 2003 | 10:15 PM
graphic's Avatar
Default Re: (Tein Man)
yeah i don't understand it...i am trying everything to figure it out...this **** sucks man
Old Sep 19, 2003 | 11:15 PM
Captn. Save A Hoe's Avatar
my boy's 98 lude put down 476 at 20psi....
Old Sep 19, 2003 | 11:26 PM
rjardy's Avatar
Default Re: (The P.I.M.P)
check his other thread, its WAY to lean.....
what is this myth about H22's not making power under boost? Im sure you can pick up at least 50 HP tuned corectly, you allso may want to lose the MF2 crap.
Rob
Old Sep 20, 2003 | 02:04 AM
93TurboSi's Avatar
Default Re: (rjardy)
looks like your running to lean at first then you dip past normal into a little to rich then right back up into a lean mixture. becareful you might blow the engine running that lean.
Boost3d22
Mar 29, 2005 09:10 AM
juka
Dec 10, 2004 11:57 AM
turbotypeR@SPEC
Mar 19, 2004 09:45 AM
graphic
Sep 20, 2003 12:48 PM
r7
Aug 20, 2003 11:11 AM
