Profec B Spec II setup help pls
Old Sep 17, 2003 | 09:11 PM
xci_ed6's Avatar
Default Profec B Spec II setup help pls
I am helping my friend tune his RSX and were haning problems w/ the boost controller. It is a base model auto FYI.
1st gear-10.4psi
2nd gear-8.7 psi
3rd gear-6.5 psi
4th gear-5.2psi
and it spikes to about 9 psi between gears
Boost is set at 20%, gain at 100% (instructions say to increase if boost decreases through gears), warning at 12.5psi, warning cut at 10%.
The goal is to get 11psi flat through all gears w as little spike as possable. Any tips or tricks are apritiated.
Thanks,
-Dustin
Old Sep 17, 2003 | 09:41 PM
LiLOtaku's Avatar
Default Re: Profec B Spec II setup help pls (krustindumm)
Whats the vacuum source your using for the solenoid?
also, the more gain you have, the more its gonna want to spike on ya. Try messing with the gain as well.
Old Sep 17, 2003 | 09:56 PM
BodyKits NW's Avatar
Default Re: Profec B Spec II setup help pls (LiLOtaku)
Man, why did they have to make it more complicated. Why change a good thing lol. Turn the **** and your set lol.
Old Sep 17, 2003 | 11:21 PM
Boost2NA's Avatar
Default Re: Profec B Spec II setup help pls (BodyKits NW)
what is the stock wastegate spring (how many psi). Also what size turbo is it. Ummm id say go in and check all the vacum lines that have anything to do with the controller. You also need to have the solenoid vacum lines as close as possible to the turbo. One more thing id say go and check the solenoid and make sure you have it hooked up right. One side is for external gates and the other is for internal. Hope that helps you. Ill be installing my spec 2 this weekend.
Old Sep 18, 2003 | 03:39 AM
rjardy's Avatar
Default Re: Profec B Spec II setup help pls (Boosted99Si)
How do you spike between shifts? do you not let off the gas?
Rob
Old Sep 18, 2003 | 06:25 AM
xci_ed6's Avatar
Default Re: Profec B Spec II setup help pls (rjardy)
I checked 3 times, the lines are hooked up correct. I just need some good base settings to start with. And yes, shifting is done w/o lifting the throttle.
-Dustin
Old Sep 18, 2003 | 12:30 PM
xci_ed6's Avatar
Anybody running the profec b spec II, could you pls post your settings?
-Dustin
hoskos
Feb 21, 2007 06:21 AM
SPOOLED
May 23, 2005 07:51 AM
boost junky 71
Aug 7, 2004 10:07 AM
integ2
Jun 15, 2004 06:44 PM
