Crank damage
Old Jan 16, 2004 | 01:07 PM
ZoRG's Avatar
Default Crank damage
If a crank is damaged can it be welded? One of the surfaces has been worn out by what looks like oil starvasion to about .5mm or so, I have a local company that does great work on cranks, that can weld it up and grind it down to oe specs again, what I would like to know is if anyone has tried it, and also if it will weaken the crank?
Thanks.
Old Jan 16, 2004 | 02:28 PM
ZoRG's Avatar
Default Re: Crank damage (ZoRG)
Anyone?
Old Jan 16, 2004 | 02:39 PM
quickergixxer's Avatar
my cousin had to have his journels welded up on his prelude crank, crankshaft supply did and they are very reputable so it must me ok
Old Jan 16, 2004 | 03:36 PM
earl's Avatar
To fix it properly with welding grinding and heat treating, it will cost more than buying a used one.
Old Jan 16, 2004 | 04:12 PM
99blackcivicSi's Avatar
Default Re: Crank damage (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">To fix it properly with welding grinding and heat treating, it will cost more than buying a used one.</TD></TR></TABLE>
machine shops are not cheap. also cranks range form 50-200 bucks taht are in good condition man just buy a used one.
mar778c
Feb 4, 2007 07:14 PM
A-busive
Aug 1, 2006 10:49 PM
turbohf
Dec 6, 2005 12:47 PM
johnzm
Jan 24, 2005 05:28 PM
BlueSi2k
May 8, 2003 11:08 AM
