Clocking the turbo questions.
Old Jan 14, 2004 | 05:08 PM
cinq's Avatar
Default Clocking the turbo questions.
Hi everyone...just wondering how easy it is to clock the precision turbo so it will point down instead of straight out like how it came. Can someone give a step by step instruction on how to do that? I searched. Found some, but not clear enough....lemme try once more to look for ones with good explanations.
Old Jan 14, 2004 | 05:12 PM
BioXide02's Avatar
Default Re: Clocking the turbo questions. (cinq)
hmm when I searched it came up with replies.. maybe this thread will help you out https://honda-tech.com/zerothread?id=470993
Old Jan 14, 2004 | 05:29 PM
cinq's Avatar
Default Re: Clocking the turbo questions. (BioXide02)
Thanks..I saw that one...just those bolts?
Old Jan 14, 2004 | 05:38 PM
ScrapinSi's Avatar
yup... just the bolts that are on the compressor housing... dont bother with the center section bolts.
Old Jan 14, 2004 | 05:44 PM
Cramerox's Avatar
Default Re: Clocking the turbo questions. (ScrapinSi)
Dont loosen the bolts all the way.....because if you do, it might cause some play with the blades ...unless tighten the correct way.
Old Jan 14, 2004 | 07:41 PM
cinq's Avatar
Default Re: Clocking the turbo questions. (Cramerox)
Wow guys...it's easier than I thought. Thanks a bunch. I didnt loosen anything too much, just enough.
patrick4588
Jun 29, 2007 09:33 PM
zexifiedlude
Nov 27, 2005 07:48 PM
pro547
Jun 20, 2005 12:54 PM
yellow blur
Apr 9, 2003 11:58 PM
HondaCutter
Sep 6, 2002 12:28 PM
