hack with check valves?
Old Jan 15, 2004 | 08:20 PM
self_made's Avatar
Default hack with check valves?
Ive used the hack on several friends cars with no problems, but they've all been civics. On my lude, Im using dsm 450's and an safc. when I hit boost for a while, it throws a cel code for the map. I was told that its since my settings are so positive(-10's), can I fix this by placing check valves? or will that throw off the hack settings?
Old Jan 15, 2004 | 09:04 PM
self_made's Avatar
Default Re: hack with check valves? (jz)
I have a venom intank, not installed yet tho..but Ill try it out. But my question is..civics and integras run -35 to-40ish right? they're stock injectors are 240cc, preludes are 340ish cc... wouldnt -38 be kinda lean?
Old Jan 15, 2004 | 09:12 PM
civicshowracing65's Avatar
Default Re: hack with check valves? (VTECNLUDE)
if your running 440cc...here is a roundabout estimate
340/440 = 77%
so therfore you would lean it around -33%
get it?
340/440 = 77%
340/550 = 61%
this should solve your cel light. You won't need check valves when you hack it
Old Jan 15, 2004 | 09:29 PM
self_made's Avatar
Default Re: hack with check valves? (civicshowracing65)
so on a civic(240cc) with dsm 450's, your calculations lead me to having to lean it out to -53?
240/450 = 53%
Im not that good at math, correct me where Im wrong
REDLINEtypeR
Nov 18, 2007 05:43 PM
93accordNOS
Mar 2, 2006 07:04 AM
Mr_Bojangles
Mar 7, 2005 09:29 AM
spike
Sep 18, 2003 01:59 PM
89dxhunchback
Jun 6, 2003 05:31 AM
