For the JRSC guys
Old Jan 15, 2004 | 11:40 AM
HT Chaplain's Avatar
Loved
Default For the JRSC guys
Can you modify a the JR BTC to work for a obd0 car. I converted my gsr engine to obd0 so it would plug directly into my crx.
Old Jan 18, 2004 | 01:39 PM
Loved
Default Re: For the JRSC guys (legutki)
BUMP
Old Jan 18, 2004 | 02:51 PM
keebler65's Avatar
yes, mine works perfectly on my CRX. just get the pinouts for your ecu to figure out which wires to use
Old Jan 18, 2004 | 03:25 PM
Loved
Default Re: For the JRSC guys (keebler65)
Cool that what i thought but i wanted to make sure. I be hooking it up to a pr3. Is the BTC worth the money? You can actually adjust the boost for the tpe of driving your doing?
Old Jan 18, 2004 | 04:56 PM
keebler65's Avatar
mine is on a PR3 as well just for your piece of mind. let me know if you have questions on the install when the time comes.
to answer your second question, yes you can adjust it whenever you want. what you do is set your distributor timing to stock, and then use the BTC to retard your timing to what you want per pound of boost. i keep my **** at 12 o' clock for daily driving, which is 1.0 deg retard per pound of boost. if i'm racing or its a cold night, i will turn it down a few clicks (each click is .1 deg) to .7 or .6 depending on the conditions. you will notice a HUGE difference in power when comparing the BTC to a car with the timing retarded at the distributor be sure to buy a used one though, because they are easy to find and you'll save a lot (they are too much money brand new).
Old Jan 18, 2004 | 05:02 PM
Loved
Thanks alot im just waiting to get some time off so I can install everything at once.
ZackKVtec
Mar 31, 2005 05:36 AM
2K Teggy
Nov 4, 2003 04:02 PM
MartyMarGSR
Apr 2, 2003 07:35 AM
HybridMT
Jul 1, 2001 10:56 AM
