basic maintenace befrore turbo...
Old Jan 16, 2004 | 10:21 AM
JDM_EH2's Avatar
Default basic maintenace befrore turbo...
i will be instlling a greddy turbo kit on my d. it has 117,xxx on it...what should i do as far as replacing things. spark plugs, wires, etc. what all should i look into. im gonn keep the internals stock for now...im only looking for aout 200-220 hp for now until i get a bigger turbo...help me out please... i want to get the install underway!
Old Jan 16, 2004 | 11:14 AM
Buzzbomb's Avatar
Default Re: basic maintenace befrore turbo... (BoostedCivic94)
200~220 is a little unrealistic considering what setup you're going to have. Expect somewhere in the neighborhood of 160whp, or less.
The biggest thing you need to check is the compression of the motor. The numbers need to be within 20% of each other.
Other things to change in addition to what you already listed would be a bigger fuel pump and new fuel filter. Good luck.
Old Jan 29, 2004 | 06:02 AM
JDM_EH2's Avatar
i will be running 10-12 psi...so its not unrealisitic...considering the numbers on this board i see with greddy turbos...
Old Jan 29, 2004 | 07:30 AM
DownBoyDown's Avatar
bump....Id like to know also!
Old Jan 29, 2004 | 07:53 AM
specv5150's Avatar
my two cents is change as much **** as you can while you are working in there. To me while installing bigger injectors, turbos, etc take the extra time to change the spark plugs, fuel/oil filter, oil. That is easy ****. Also would recommend a new clutch before or soon after. I was thinking of other things but it esacpes me right now
Old Jan 29, 2004 | 08:23 AM
COOKIEPUSS's Avatar
Compression test
timing belt/water pump
fuel/oil filter
Plugs and plug wires..I suggest NGK for both.
Clutch before Turbo, and if you want flywheel (doesn't have to be done, but if your changing the clutch and want to do a lighter flywheel, you should do it at the same time.)
bumper fluid
Old Jan 29, 2004 | 08:51 AM
Buzzbomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedCivic94 &raquo;</TD></TR><TR><TD CLASS="quote">i will be running 10-12 psi...so its not unrealisitic...considering the numbers on this board i see with greddy turbos...</TD></TR></TABLE>
Sorry, I was under the assumption you were going to run stock boost.
joshcivic00
Jul 19, 2005 10:23 PM
Integra99GSR
Nov 23, 2003 01:25 PM
efracer
Aug 4, 2003 08:06 PM
Thrillhouse
Sep 5, 2002 11:22 AM
sporter
Jun 25, 2001 08:48 AM
