Car shuts down everytime I go and do a complete stop>>
Old Jan 14, 2004 | 04:41 PM
Mr.DC2TurBo's Avatar
Default Car shuts down everytime I go and do a complete stop>>
Okay, I just did my pistons and rods done and now every time I start going (accelerating) and doing a complete stop my car would die. The needle just drops fast down to close to the 0 mark and then it dies and I have to restart. I'm running 440cc injectors afc hack in my LS integra. Car was running fine before installing the pistons and rods. Any info would help a lot.
Old Jan 14, 2004 | 04:42 PM
5thgencivic's Avatar
Default Re: Car shuts down everytime I go and do a complete stop>> (Mr.DC2TurBo)
Didn't you already post this?
Old Jan 14, 2004 | 05:59 PM
Default Re: Car shuts down everytime I go and do a complete stop>> (5thgencivic)
I'm wondering if it could be my wire sand spark plugs.
Old Jan 14, 2004 | 06:19 PM
redboost10's Avatar
i had the same problem when i put in my new pistons and valve train. all i did was messed with my throttle cable(that nut on the intake mani) and it idles smooth at 750 rpm
Old Jan 14, 2004 | 06:27 PM
Default Re: Car shuts down everytime I go and do a complete stop>> (tgh99si)
can it be the timing and having some old plugs and wires? My installer told me if I want my motor to last I can to drive under 3K rpm and no more than 60 for about 1000miles.
Old Jan 14, 2004 | 06:28 PM
Mase's Avatar
fuel/ign probably, i bet ur afr is way off.....
Old Jan 14, 2004 | 06:29 PM
redboost10's Avatar
i had brand new plugs in mine and the timing wasnt retarded or antying
Old Jan 14, 2004 | 06:34 PM
Default Re: Car shuts down everytime I go and do a complete stop>> (Mase)
thats the thing, before isntalling interals everything was fine and now this. I thought it could be my air/fuel mixture so I lean it out to around -37 from 1-3K rpm and it seems to work for now. I'm just afraid it will happen again bc I can see the needle still dropping real close to 0 and wanting to die out on me. Just wanted to see if anyone knew if that was normal or the caused
Old Jan 14, 2004 | 06:48 PM
InTeGrA B18b1's Avatar
does your rev go up and down sometimes?
Old Jan 14, 2004 | 06:49 PM
redboost10's Avatar
Default Re: Car shuts down everytime I go and do a complete stop>> (InTeGrA B18b1)
if its very cold out
Old Jan 14, 2004 | 07:01 PM
nope. its fine while idling but once I try to do complete stop (ie from stop lite to stop lite) it some times die.
Old Jan 14, 2004 | 08:43 PM
ekb18c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">fuel/ign probably, i bet ur afr is way off.....</TD></TR></TABLE>
Once you installed pistons and rods in the motor, you have a completely different motor and every motor is different.
cheap2
14
Jun 13, 2009 02:39 PM
96civic909
10
Oct 15, 2008 05:54 AM
green eyed bandit
Mar 24, 2008 06:27 PM
TrnsferErr
Dec 31, 2004 05:35 PM
Mr.DC2TurBo
Jan 14, 2004 04:03 PM
