does someone have a compressor map for sc34
can anybody share this with the .48 ar if it matters? also in yalls oppinion would you put the on a b16 84mm bore? 8.8:1 with sufaced block and surfaced head?
Modified by dc2_and_ef at 5:07 PM 1/15/2004
Modified by dc2_and_ef at 5:12 PM 1/15/2004
Here's your map: You'll probably need to read up on the baest way to plot your application.. You'll need a lot of boost considering you dropped your compression so low on a B16, it's hard to tell what it will do.. But you will need to up the boost.
http://www.turbofast.com.au/FlowTO4E.html
art what do you think with this setup, and that turbo?
