Umm I think I got a BIG problem.
Old Jan 17, 2004 | 11:24 AM
I Gotta Question's Avatar
Default Umm I think I got a BIG problem.
Yeah well when I built this kit im installing I was planning on starting with low boost and then as time goes by rebuild the block sleeve, etc, etc, So in turn I got a WG with a 14lb spring, now that I think of it, doesnt a boost contoller only help you go over the springs rating and not under or am I wrong, I want to know this before i go any further. Thanks
edit: Now that I think about it more the boost controller uses the boost to regulate when the spring opens and there are 2 ports on the wastgate one above the spring and one below, so I guess the controller can hold the spring down or open it up, so I guess I answered my own ? thanks alot guys
Old Jan 17, 2004 | 11:29 AM
b18cx's Avatar
Default Re: Umm I think I got a BIG problem. (I Gotta Question)
You can only go as low as the spring in the wastegate. If you have a 14psi spring, the lowest you can go is 14psi. you can go over wiht the boost comntroller.
Old Jan 17, 2004 | 01:11 PM
Default Re: Umm I think I got a BIG problem. (b18cx)
ahh **** that sucks theres no other way maybe put vacuum through the controller or somethin
Old Jan 17, 2004 | 01:43 PM
FredoSP's Avatar
buy a new spring?
Old Jan 17, 2004 | 02:59 PM
Shawn C's Avatar
In The Garage
Default Re: Umm I think I got a BIG problem. (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">buy a new spring?</TD></TR></TABLE>
Old Jan 17, 2004 | 04:49 PM
Default Re: Umm I think I got a BIG problem. (ShadyEH2)
where can I get a 5psi spring at, I searched ebay, but no luck, anybody?
Old Jan 17, 2004 | 04:55 PM
MaxBoostC1's Avatar
wut kinda WG u have&gt;&gt;???
Old Jan 17, 2004 | 05:36 PM
Default Re: Umm I think I got a BIG problem. (DFW_EK)
35mm external wastegate w/12psi spring, I thought it was 14. Tial or Deltagate
Old Jan 17, 2004 | 09:57 PM
MiraiZ's Avatar
Tial and delgate = big difference....does it look like a disk or a big door ****?
Old Jan 18, 2004 | 12:22 AM
Default Re: Umm I think I got a BIG problem. (MiraiZ)
door ****
Old Jan 18, 2004 | 02:27 AM
vtekthis's Avatar
it should say tial right on it! if so check out ben@importparts.com, he is an h-t member and has the springs you need.
Old Jan 18, 2004 | 11:49 AM
Default Re: (vtekthis)
It doesnt say Tial but it looks like a Tial.
Old Jan 18, 2004 | 11:58 AM
alpha's Avatar
Default Re: (I Gotta Question)
It's probably one of the wastegates sold on eBay? If your boost controller is hooked up you can boost from the spring rate and up. If it's not hooked up you can boost up to the spring rate. I hope this helps.
Old Jan 18, 2004 | 12:08 PM
Default Re: (0x64)
yeah that helps but what spring do I need to use?
Old Jan 18, 2004 | 12:11 PM
alpha's Avatar
It depends how much you want to boost or what your power goals are. If you are not looking for a high horsepower monster just get a 7lb spring or 9lb spring and a boost controller.
Old Jan 18, 2004 | 12:32 PM
Default Re: (0x64)
Yeah I know that, I just want to know what kind I need to get, since there isnt really a brand for it. Do I just get one for Tial?
Old Jan 18, 2004 | 12:38 PM
alpha's Avatar
Yeah. That should work fine.
Old Jan 18, 2004 | 12:41 PM
Default Re: (0x64)
Alright thanks, now all I have to do is find one local.
91integraLSVTEC
Oct 21, 2009 11:09 AM
*Boostwerks*
Apr 3, 2005 05:55 PM
TurboCoop
May 19, 2004 12:21 PM
BioXide02
Dec 22, 2003 11:41 PM
filetofit
Jul 23, 2002 10:42 AM
