walbro fuel pump install questions
Old Jan 16, 2004 | 03:19 PM
sleepyhamsterlx's Avatar
Default walbro fuel pump install questions
well reading over the instructions on c-speedracing.com they are using the stock wires to hook it all up, is this good or not. It wouldn't see 10psi ever so im just wondering if i should get better guage wiring or a relay.
Old Jan 16, 2004 | 03:21 PM
baphomet's Avatar
Default Re: walbro fuel pump install questions (sleepyhamsterlx)
Mine works fine as a direct swap with the OEM one.
Old Jan 16, 2004 | 03:34 PM
Default Re: walbro fuel pump install questions (slashDEVslashNULL)
so is that only necessary with an inline fuel pump
Old Jan 16, 2004 | 03:48 PM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepyhamsterlx &raquo;</TD></TR><TR><TD CLASS="quote">so is that only necessary with an inline fuel pump
It depends on how much power the pump draws. If you are blowing the fuse, then you need to do it.
Old Jan 16, 2004 | 04:20 PM
rtype11's Avatar
I went nuts with mine and had a buddy weld a stainless AN fitting to bulkhed where the barb fitting was so I could run a real -8 from the pump. Also have 10gauge from alternator to relay, my pump see's an extra 1.5volts over stock this way.
Old Apr 5, 2008 | 07:28 AM
dmotoguy's Avatar
Default Re: walbro fuel pump install questions (rtype11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">I went nuts with mine and had a buddy weld a stainless AN fitting to bulkhed where the barb fitting was so I could run a real -8 from the pump. Also have 10gauge from alternator to relay, my pump see's an extra 1.5volts over stock this way.</TD></TR></TABLE>
I'm planning on doing the same, does it matter that the rubber line from the pump to the fuel line is 5/8"
also, I wanted to use the stock line for the return, is there much reason to do this?
95BoostedEJ1
Sep 7, 2008 06:27 PM
k-series
Sep 10, 2006 10:01 AM
Lonnieboosted
Aug 13, 2006 10:31 AM
hovic
Mar 12, 2006 03:43 PM
BlueShadow
May 29, 2005 11:08 AM
