why wont my intercooler fit?
my piping on the intercooler doesn't line up to my intake manifold(skunk2) its greddy's smaller intercooler. do i need a new manifold or what? im stuck!
Re: why wont my intercooler fit? (Boosted GSR)
it's pretty obvious. The stock gsr mani faces toword the bottom, while the skunk2 faces towards the top. They position the t/b different from each other
Re: (thermalfi'd16)
How close to fitting is it? I notice sometimes if you think backwards you can get things done. We ended up putting my upper charge pipe on first then going from there.
Re: (Boosted GSR)
the gsr charge pipe will fit only on the stock gsr intk manifold bc the t/b is lower than ls and type r. so if u use skunk2 or jg manifold, u will need an ls charge pipe.
then u will have to cut towards the end of the pipe where the t/b connects bc it is too long. if u want i have a ls charge pipe that has been fitted for ur jg or skunk2 manifold that goes through the stock intake hole of a civic. if u want i will trade my ls for ur gsr charge pipe.i need a gsr charge pipe bc i am doing a lsvtec with a stock manifold.
Realtimeb18c1
08-23-2003 10:54 PM
