Turbo Set UP! ECU Turbo CHIP help.. Opinnions
wasup yall, I need ur opinnion on this, let me know what Yall THINK.! here~s the link.. and here's my Set Up its not one of the best but it's all good... I personally think its safe cuz I know alot of people boosting Gsr and B16 and PLS. correct me if i'm wrong but the compression on a gsr is around 10's right ? wrong?? so me with that gasket should be fine..
FULLY BUILT
95 D16z6 (using crx si manifold and Distributor)
Eagle Rods
hihg compression pistons
GREDDY head gasket (2.0mm THICK)
Garret T3 Turbo
450 DSM injectors
Chipped ECU (check the link)
B&M fuel pressure Regulator 45psi
Intercooler
The COMPRESSION used to be 10:5 (i know its high for Turbo) but I added a Thick headgasket so it should LOWER the COMPRESSIOn.
I just got this CHIP i'm about to install it! let me know what you guys think!! check out the LINK
http://cgi.ebay.com/ebaymotors...09864
by the way i'm only boosting 4psi. about to raise the boost to 6psi
FULLY BUILT
Eagle Rods
Garret T3 Turbo
450 DSM injectors
Intercooler
