How much total timming are you running under boost ????????
Old Jan 15, 2004 | 04:44 PM
CRVRX's Avatar
Default How much total timming are you running under boost ????????
Lets say at 10psi at 8000 rpm on pump gas 91 or 93oct)
Then at 15psi at 8000rpm.
Thanks!
Old Jan 15, 2004 | 05:31 PM
wade's Avatar
Default Re: How much total timming are you running under boost ???????? (CRVRX)
i wanna know too
Old Jan 15, 2004 | 05:39 PM
PHiZ's Avatar
Default Re: How much total timming are you running under boost ???????? (wade)
Different motors have different base timing. So there needs to be more qualifying information.
-PHiZ
Old Jan 15, 2004 | 05:47 PM
lugnuts's Avatar
souds like a good question to ask at an EFI101 Seminar
Old Jan 15, 2004 | 06:06 PM
CRVRX's Avatar
Default Re: How much total timming are you running under boost ???????? (lugnuts)
OK,
10-1 comp motor, 10 psi , 8000rpms, Type R cams, 1.9L displacement. Pump gas, Intake temp around 160deg F....
What kind of timming do you run.....14 deg, 18 deg, 20 deg??? etc.
Just need it for refrence.....
Old Jan 15, 2004 | 06:25 PM
K20Ahondas's Avatar
14 degrees at idle can you get up to 20lbs on race gas and 14lbs on pump..but that's with 93 oct. With 91, 10-11lbs with 14-15 degrees.
Old Jan 15, 2004 | 06:50 PM
PHiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX &raquo;</TD></TR><TR><TD CLASS="quote">OK,
Just need it for refrence.....</TD></TR></TABLE>
If base timing is 16.5 I will end up with about 20degrees advance at 8k, 10PSI full load.
-PHiZ
Old Jan 15, 2004 | 06:52 PM
W C L's Avatar
on all the turbo cars i work on... i use the "for every 1 lbs of boost i back it off .5 degrees"...
Old Jan 15, 2004 | 07:02 PM
K20Ahondas's Avatar
Default Re: How much total timming are you running under boost ???????? (PHiZ)
on 20lbs we run about 26 degrees full timing on race gas.
Old Jan 15, 2004 | 08:00 PM
CRVRX's Avatar
Default Re: How much total timming are you running under boost ???????? (1FSTCAR)
Thanks guys, I just needed some ideas .
Poey2
Jul 31, 2008 11:01 PM
92 civic VX B18c
Jan 17, 2005 05:12 PM
2k.civic.si
Nov 29, 2004 06:39 PM
rocket256
Jul 10, 2004 03:18 PM
TurboLSVtecTeg
Sep 24, 2003 02:32 AM
