Leakdown results, need help interpreting
Old Jun 1, 2004 | 11:11 AM
Andrew 825SM's Avatar
Default Leakdown results, need help interpreting
My results from cylinder 1-4 are 10%, 14%, 4%, 4% done on a cold motor. I hear air hissing out of my pcv valve on cylinder 1 and 2. Does that mean that my rings in those 2 cylinders are worn or is the headgasket leaking?
Modified by Andrew 825SM at 4:13 PM 6/1/2004
Old Jun 1, 2004 | 12:24 PM
DRAGLS's Avatar
Default Re: Leakdown results, need help interpreting (Andrew 825SM)
ya that usually means the rings...
Old Jun 1, 2004 | 01:11 PM
Vtec92Civic's Avatar
Default Re: Leakdown results, need help interpreting (DRAGLS)
aww man that sucks . . . . I have personally never done a leakdown test, but I hope when I do that things are ok. Are you blowing any blue smoke?
Old Jun 1, 2004 | 02:41 PM
Default Re: Leakdown results, need help interpreting (Vtec92Civic)
no smoke, compression test is 180-180-180-185. Am I in for a necessary engine rebuild?
Old Jun 1, 2004 | 03:04 PM
Teg4e's Avatar
A year ago I had a leakdown test of 35% on cylinder 1 and 10-15% on the other cylinders. It's making less power than other similar setups, but it hasn't blown in over a year. I'm not concerned about the block though, as I plan on getting another used LS block to replace when this finally lets go.
Old Jun 1, 2004 | 03:06 PM
Stewie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew 825SM &raquo;</TD></TR><TR><TD CLASS="quote">no smoke, compression test is 180-180-180-185. Am I in for a necessary engine rebuild?</TD></TR></TABLE>
That's exactly why I say compression test are inaccurate. Next time just leave the oil filler cap off and listen for air through there.
Old Jun 1, 2004 | 04:34 PM
gritsak's Avatar
Default Re: Leakdown results, need help interpreting (Family Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Family Guy &raquo;</TD></TR><TR><TD CLASS="quote">
That's exactly why I say compression test are inaccurate. Next time just leave the oil filler cap off and listen for air through there.</TD></TR></TABLE>
not really inaccurate, just measure different things..
Old Jun 1, 2004 | 06:55 PM
Default Re: Leakdown results, need help interpreting (gritsak)
I did the leakdown test again when my car was warm and I got a set of new percentages 3%, 2%, 2%, 3%. I felt so relieved. I guess I don't need to worry anymore.
Old Jun 1, 2004 | 07:06 PM
slim9300's Avatar
I don't think your PCV valve should be leaking if you don't have vacuum in the intake manifold. Maybe you should get a new one, or it was partially out when you were doing the leakdown. Any other thoughts on this?
ONE*SICK*FERIO
Sep 27, 2010 10:22 AM
Convert
14
Mar 4, 2008 10:21 AM
sik96teg
Feb 29, 2008 06:36 AM
trecool44
Jun 19, 2007 06:52 AM
silverboost
Nov 8, 2005 01:01 PM
