what settings for cam gears on factory cams for turbo civic
just wondering if anyone has played with their factory civic si cams, i have a turbo 99si and havent ever moved my cam gears cause everyone said they dont net any HP they just lose it. i have a set of OBDII gsr cams but havent put em in yet, anyone have any settings other than stock????
H-T White Ops
Re: (NextelBuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NextelBuddy »</TD></TR><TR><TD CLASS="quote">stock cam gears are not adjustable from my understanding</TD></TR></TABLE>
They aren't. Also, the only way you're going to be able to pull any power out of adjustable cam gears is to get it on a dyno. Even if you have 2 cars running the exact same setups, just because one setting works for one doesn't mean it's going to work for the other.
Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">
They aren't. Also, the only way you're going to be able to pull any power out of adjustable cam gears is to get it on a dyno. Even if you have 2 cars running the exact same setups, just because one setting works for one doesn't mean it's going to work for the other.</TD></TR></TABLE>
soulrider4ever
03-01-2007 09:12 PM
