MAP sensor problem, need help
Old May 31, 2004 | 05:18 PM
Vinhtran17's Avatar
Default MAP sensor problem, need help
I just turbed my car, and have found out that my missing link was fucked up (fucked up to begin with) so now i have built my little ghetto check valves and have installed it. now when i boost in 1st and 2 and gears its fine, but then when i'm in third and still boosting, the check engine light goes on. im not sure what the problem is. is it because im not using enough check valves?(i got 3 valves goin) or is this is common problem for check valves. oh yeah im running like 6 psi (but then boost creeps up to like 9 or 10 ( i thin beacuse of my wastegate gasket)
but if anyone could help me, that would be great. thanks to all that helped
Old May 31, 2004 | 08:54 PM
Vinhtran17's Avatar
bump
Old May 31, 2004 | 09:07 PM
turbo*s2k's Avatar
Default Re: MAP sensor problem, need help (Vinhtran17)
go back to the missing link. Check valves!
Old May 31, 2004 | 09:25 PM
Vinhtran17's Avatar
ill go back if you can find me any missing links for sale or anything. ( the ones i bought dont work.)
Tr0LL
Jan 4, 2008 09:25 AM
nicktagz
Sep 28, 2006 08:04 AM
Blanket Jackson
May 25, 2004 07:59 PM
Pengo
Jul 30, 2002 08:43 PM
turbotec
Feb 26, 2002 03:34 PM
