Oil leak from oil return line...
I just put a Drag turbo kit on my Accord three weeks ago. I'm getting a oil leak from the return line. It's coming from fitting on the oil pan. I bought the Goodridge stainless steel lines to help keep it from leaking. I heard that you have to weld the nut on the inside of the pan to it to keep it from leaking also. But, I've also heard there's some kind of washer that you can buy to put on the nut to keep it from leaking instead of welding it to the oil pan. Does anyone have another suggestions for me to do other then welding the nut to the oil pan. Any help would be greatly appreciated.
Thanks guys...
Thanks guys...
Re: Oil leak from oil return line... (roydogg)
I already have the oil return line kit, so are you trying to say that I need to get the Turbo Threaded Oil Drain Flange kit?
guymosiris
11-26-2003 06:50 AM
