mitsu 14b turbo seal replacement??
Well for some reason my turbo is using lots of oil, I think it might have been caused by a bad regulator. It was so rich at idle that gas was dumping out of the DP, But i had no way to get it back home other then driving it so i just went for it..
Anyways, Now it is dumping oil out of the compressor inlet, And smoking really bad! Anybody know if the seals DIY are replacable?? I searched a little but came up with nothing?
Any help would be appriciated
BTW, DO you think the seals would make it smoke really bad!!??
Re: mitsu 14b turbo seal replacement?? (highpsief)
yea..happend to my 14b. smoked horribly...you can search eBay for the kit ~99 bucks I belive. I think the only tool you will need are Circlip pliers. Some people don't recommend rebuilding turbos yourself, b/c the shaft has to be spin balanced @ many thousand rpms.....
igo4bmx
06-02-2003 06:54 PM
