Do I need Fmu with this setup?
Old Jun 1, 2004 | 10:02 AM
Turbocivic94's Avatar
Default Do I need Fmu with this setup?
Aem FPR (1:1)
310cc Injectors
7 psi
Old Jun 1, 2004 | 10:33 AM
Turbo E's Avatar
Default Re: Do I need Fmu with this setup? (Turbocivic94)
got a fuel pump?
Old Jun 1, 2004 | 11:33 AM
Rod.'s Avatar
Default Re: Do I need Fmu with this setup? (Turbo E 604)
I used one at 8psi on my civic. I had 310 injectors,6:1 fmu, and fuel pump. I believe you can get away without a fmu if you have a fuel pump
Old Jun 1, 2004 | 01:33 PM
Default Re: Do I need Fmu with this setup? (redturbocivic)
dont have fuel pump but I can get one.
Old Jun 1, 2004 | 01:56 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">I used one at 8psi on my civic. I had 310 injectors,6:1 fmu, and fuel pump. I believe you can get away without a fmu if you have a fuel pump</TD></TR></TABLE>
You going to give him $2k when he blows up his motor? LOL!
If you're going to go cheap, at least go with a proven fuel setup. AFC hack or FMU.
Old Jun 1, 2004 | 01:58 PM
Turbo E's Avatar
you should be ok up to 5 psi, but if you carank up the regulator pressure you can do more, but your car will idle like ****.
as you have the 310 cc inJ, maybe look into the uberdata fuel management.
sooner or later you'll blow up without proper fuel control.
Old Jun 1, 2004 | 03:04 PM
Default Re: (Turbo E 604)
right now I have hondata but I didnt want to tune it. I wanted to throw the kit on my daily driver till my motor is out of machine shop. well my daily driver has ls/vtec in a 94 civic coupe with pr3 piston so the compression is like 11.3. that's why I dont want to run too much boost. I think I'm just gonna borrow a fmu and run like 7 psi. thanks for your help guys.
DXturbo
Jul 1, 2003 08:28 PM
gsr sol
Aug 29, 2002 09:18 AM
zcivic91
Jul 30, 2002 08:58 AM
97GSRT
Mar 28, 2002 04:21 AM
