turbo problem
Old May 31, 2004 | 01:08 PM
corey's96GSR's Avatar
Default turbo problem
i just put a turbo on my OBD0 b16. my problems is when i get on it when it gets to 6500-7000 rpms it acts like it hits rev limiter. another guy around here is having the same problem. does anyone know what is the problem? at first i thought it just needed check valves but it didn't help. so if you know what is wrong please post.
Thanks
Corey
Old May 31, 2004 | 01:11 PM
GDM Z28's Avatar
Default Re: turbo problem (corey's96GSR)
What are you using for an EMS? You could either be running too rich or too lean in that spot. What are your plugs gaped at? Make sure you have them gaped at the right size (i believe .28 is ideal). Check those two things then let us know what happens.
Old May 31, 2004 | 03:56 PM
help
Old May 31, 2004 | 07:12 PM
KeithGSR's Avatar
I have the same issue with my 99gsr and my greddy 18g turbo. I was told by my friend it might be my spark plugs too... or a bad air flow sensor...? I just got this problem so Im looking to fix this...anymore thoughts???
Old May 31, 2004 | 07:46 PM
GDM Z28's Avatar
Default Re: turbo problem (KeithGSR)
When you go to start your car does it fire right up? or does it take awhile? (like a few cranks) I know when my plugs go bad i start to get sputtering on the high way if i give it alittle gas and it takes 2-3 times to try to start my car (2-3 times of holding the key down for like 5 secs each time). See if your plugs are fouled out 2.
Old May 31, 2004 | 08:06 PM
KeithGSR's Avatar
Default Re: turbo problem (civicflnum1)
I was told the term fouled out....I dont know what that means...with my spark plugs I think one has a broken needle so the gap might be off... My car starts right up but my rpm's start out jumpy at idle then it smooths itself and if I barely touch the gas rpm's drop hard...
Old May 31, 2004 | 08:12 PM
KeithGSR's Avatar
I meant barely touch the throttle and then no throttle causes rpm's to drop low to about 350-450...
Old May 31, 2004 | 08:18 PM
MachAF's Avatar
Fouled out means there is carbon deposits on the plugs causing it not to spark very well. It is caused by running rich.
Old Jun 1, 2004 | 07:48 AM
the car strarts up fine and runs fine it just hits this barrier at 6500-7000.
Old Jun 1, 2004 | 09:23 AM
g0ldywang's Avatar
im having the same prob right now on my obd0 b16 with the greddy kit. I checked my plugs though and gapped them right and still no change so if you get any answeres on here let me know. mine just happens much earlier.
Old Jun 1, 2004 | 12:08 PM
2000turbosi's Avatar
Default Re: turbo problem (b16agreddynx)
i had a similar problem...it was my distributor....it crapped out...maybe check that out if all else fails...
Old Jun 1, 2004 | 12:46 PM
1316130057's Avatar
Default Re: turbo problem (2000turbosi)
Keith, sounds like you're fouling out on off-throttle enritchment
Corey, you're blowing out your candles.
Old Jun 2, 2004 | 10:17 PM
KeithGSR's Avatar
Default Re: turbo problem (1316130057)
My spark plugs were fouling out, thanks for that idea...What its now boosting positive... but I think it seems jumpy in the acceleration...I also experience a strange sensation while getting on the petal one time. I believe I was over boosting then it was before It seem like it was just going to keep boosting the more gas I gave it. Is this the actuator rod?
Old Jun 3, 2004 | 07:08 PM
1316130057's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeithGSR &raquo;</TD></TR><TR><TD CLASS="quote">My spark plugs were fouling out, thanks for that idea...</TD></TR></TABLE>
no problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> I believe I was over boosting then it was before It seem like it was just going to keep boosting the more gas I gave it. Is this the actuator rod?</TD></TR></TABLE>
Possible, but not too likely. Sounds like boost creep. If your manifold has a 90º turn in order to reach the wastegate, then you'll unquestionably have boost creep. What kind of manifold are you using?
Old Jun 3, 2004 | 07:28 PM
KeithGSR's Avatar
its the greddy turbo manifold... I have many poroblems in this area in the past week or so. I'm guessing something is not right, Either some part or I just need a tuning...?
Old Jun 4, 2004 | 04:10 AM
1316130057's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeithGSR &raquo;</TD></TR><TR><TD CLASS="quote">its the greddy turbo manifold... I have many poroblems in this area in the past week or so. I'm guessing something is not right, Either some part or I just need a tuning...?</TD></TR></TABLE>
I've seen 2 different manifolds from Greddy. One's cast and cracks a lot, the other is tubular with a wastegate exit pointed in the opposite direction of exhaust flow. Not sure which one you have but neither outcome looks good, to be honest. One boost leaks, the other boost creeps.
Old Jun 4, 2004 | 07:35 AM
KeithGSR's Avatar
I have the cast iron model
Old Jun 4, 2004 | 10:13 AM
1316130057's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeithGSR &raquo;</TD></TR><TR><TD CLASS="quote">I have the cast iron model</TD></TR></TABLE>
Ahh.. The boost leak model, lol. Apparantly it hasn't cracked as yet. Out of curiosity, are you running an internal waste gate (and if so, what diamater) or have you modified it to run an external waste gate?
Old Jun 5, 2004 | 10:32 AM
99blusi's Avatar
What kind of exhaust are you running? My 18G creeps up to around 10psi because of my 3" exhaust/downpipe. My boostcontroller was set at 7psi before I changed the exhaust over...
Old Jun 5, 2004 | 09:34 PM
KeithGSR's Avatar
Default Re: turbo problem (99blusi)
The waste gate seems to be in between the turbo and the radiator. I believe its a tial? Im just running vafc...
CARflyGUY
May 30, 2007 07:20 AM
Integra_drk
May 3, 2006 09:37 AM
ralfspeed
Jun 12, 2005 06:29 PM
corey's96GSR
Jun 6, 2004 08:37 PM
_VTI-R_
Mar 12, 2003 02:50 PM
