How Much PSI
Old Jun 2, 2004 | 10:48 AM
ELAMINT5's Avatar
Default How Much PSI
I am new to the Turbo side of the world. And was wondering if you can tell or calculate what PSI I would have to be to put down 400 whp in my CRX. I have a B16A1. I am looking at the REV HARD and DRAG kits and do not know which one to get. The block was just Sleeved with DART sleeves and honed out with JE 9.0 comp pistons and Eagle Rods. Stock crank though. I am still running the stock ECU though, I am looking to go OBD1 and get the Hondata S200 program. Any information would be greatly apperciated!
thanks
Old Jun 2, 2004 | 10:55 AM
ykracing's Avatar
Default Re: How Much PSI (ELAMINT5)
well that will depend on the size of the turbo...
Also, dart doesnt make sleeves...
Old Jun 2, 2004 | 12:38 PM
Muckman's Avatar
Moderator in Chief
Darton = Sleeves = http://www.darton-international.com
Dart = Aftermarket blocks and heads = http://www.dartheads.com
Old Jun 2, 2004 | 01:56 PM
USDM 4G VTEC's Avatar
on a perfect world...
u make 160 chp
if u take 22 psi, add the atmospheric pressure (14.7), then divide it by the atmospheric pressure, u get how much power more u will make.
then u multiply what the motor makes NA and the number u get then u get what it should perfectly make
for example
22psi+14.7psi=36.7psi
36.7psi/14.7psi= 2.496
2.496x160hp= 399.36 chp
of course, theres a rule that says, the stronger u make a motor NA the more power u squeze when boosted
and its true
LilCivic04
May 31, 2005 09:12 AM
LilCivic04
Feb 1, 2005 06:04 PM
1RMDave
Apr 12, 2002 12:12 AM
The Punisher
Aug 26, 2001 07:46 PM
