engine management and emmissions....!!!
Old Jun 1, 2004 | 10:39 AM
graphic's Avatar
Default engine management and emmissions....!!!
i live in NJ and the inspection station just started to hook up to the obd2 port to see if the factory ecu is there...if NOT...the you FAILED...
so what are we supposed to do???
1. Let's say i have the aem ems...and i am tuned on 18psi, 750cc injectors and 60 psi of fuel pressure...
what do i do ...install factory injectors, factory ecu and lower the fuel pressure back down to 50 psi (98 prelude specs)...and remove the wastegate spring..to prevent boost from happening???
will this even work???will i **** anything up???
this **** sux ..IMO
s.cha
Jul 10, 2010 11:29 PM
94typeR
May 3, 2007 11:16 AM
masteryoda10
Feb 22, 2006 04:24 AM
Ruben19
Jan 29, 2006 04:31 PM
