ubrdata ignition/injection
Old Jun 1, 2004 | 02:27 PM
RACEPAK's Avatar
Default ubrdata ignition/injection
hello everybody
i have few questions about uberdata.
1)do i need to change somthing else in the injection system except.
dsm 440 / resistor box / (do i need wallbro fuel pump?) accordig to what i understand i dont need an FPR while running uberdeta.?
2)do i need an msd ignition box with uberdata?
3)what spark plugs are are the best for a boosted d-serise.
Old Jun 1, 2004 | 02:40 PM
USDM 4G VTEC's Avatar
Default Re: ubrdata ignition/injection (RACEPAK)
1- i will let someone else reply to that
i just play with my own uberdata
2- no u dont, unless u want just the ignition spark increased, but the retard can be done at the ecu
3- NGK BKR7 E-11 (2 step colders)
Old Jun 1, 2004 | 03:49 PM
Sinner's Avatar
what was the stock motor? if have a d fuel pump, I would recommend upgrading.
Nick
Old Jun 2, 2004 | 07:20 AM
RACEPAK's Avatar
ttt
Old Jun 2, 2004 | 10:30 AM
Joseph Davis's Avatar
Depends on your goals.
1) I prefer high Z injectors for an ECU designed to use high Z injectors to low Z injectors + resistor hack.
2) MSD aren't needed until ~400 whp, I'd rather get s bigger step up coil or run higher voltage to my stock coil. MSD have issues.
3) Colder plugs. I suggest you read them and determine what works best for you.
Fuel pump isn't needed until closer to 300 whp at stock pressures.
Old Jun 2, 2004 | 12:07 PM
RACEPAK's Avatar
Default Re: ubrdata ignition/injection (J. Davis)
my goals are about 180 whp
civic hatchback 1994 esi (d16) euro model.
the parts i have are:
-ihi rbh5 oil and water cooled. (internal wg)
-hf manifold.
-10.5''/8.5''/2.5'' intercooler (came off a muso)
-downpipe.
-440cc injectors .
-oil press / boost gauge.
the parts i dont have are:
-bov
-chargepipes/vac lines/oil lines.
-manual boost controller.
-need to burn a chip and modify the ecu (uberdata).
have a few questions:
-can you tell me what are z injectors?
-is the turbo good for the application ?? will it rev hard???
-do i need any more vacum sources except to the bov / boost controller / boost gauge /wastegate? somthing missing ????
please need you help with this... am i missing any part? somthing???
best regards
Old Jun 2, 2004 | 12:17 PM
Z = impedance, or ohms, which covers both resistance and inductance ratings.
Which IHI you have dictates how much whp you can get from it. In the USA, the most common source of IHIs is off of the 1980's EA18 turbo Subaru engine... they don't put out more than 150 whp. If you have one of those, sell it and upgrade IMO. You stick a lot of heat into your engine, which is bad, for very little power. You'd be safer at a higher power level with a bigger compressor.
Over and above the sensors/misc currently hooked to engine vaccum, your list is correct.
Old Jun 2, 2004 | 12:23 PM
RACEPAK's Avatar
the turbo i from a diesel isusu trooper 2001
if you like i can post a pic...
and what about the vac am i good with it ?..
Old Jun 3, 2004 | 02:29 PM
RACEPAK's Avatar
ttt
Old Jun 5, 2004 | 01:03 AM
RACEPAK's Avatar
ttt
please
what is wrong with my turbo???
jasondok
Jan 5, 2007 07:31 AM
fafsa
Feb 23, 2005 07:39 AM
af97civic
Apr 16, 2004 05:58 AM
Kellindal
Dec 19, 2001 11:52 PM
