turbo installed with aqurium parts spliced on map sensor (why?)
I had this guy at the track tying out for a spot on my team and he developed a huge fuel leak (due to a crappy turbo install...his fuel rail wasnt tightened and the rail separted from his first two injectors destroying the o-rings bla,bla,bla) while I was fixing his fuel leak I was checking out his turbo setup and I noticed the crazy splice job on his map sensor, I took a closer look and they used tube splices from an aquirium company called tetra. my question is why? They did a realy slack job on the complete install...his fuel pump is zip tied to his intake manifold and he has vacum splices out of his ***! the craftmanship of this install has me questioning the purpose of this mod. any help would greatly be appreciated. check out the pics.http://www.we-todd-did-racing....D.jpghttp://www.we-todd-did-racing....DE%3D
Re: turbo installed with aqurium parts spliced on map sensor (Syner-G-Racing)
those are 1 way valves that bleeds pressure so the MAP senor does not see boost and throw a code.
he can get a missing link and a vacuum box to make it look cleaner.
Re: turbo installed with aqurium parts spliced on map sensor (GSRrR)
dont worry about man...thanks for the insight to an all motor guy now I know, I assumed it was something along the lines of that, but, after looking it over I wasnt sure. thanks again bro.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing »</TD></TR><TR><TD CLASS="quote">where can he find that at?</TD></TR></TABLE>
what, missing link?
importparts.com fourms sponsor
vacuum box?
https://honda-tech.com/zerothread?id=597051
what, missing link?
vacuum box?
