Will a InlinePro manifold and Tial 38mm w/g clear the hood on a 00 Civic SI?
Old 06-01-2004, 03:34 PM
11psiTurboSI's Avatar
Default Will a InlinePro manifold and Tial 38mm w/g clear the hood on a 00 Civic SI?
I'm not going to be using the top port for anything and I wanted to know if I'll have any fitment issues clearing the hood???
Old 06-01-2004, 04:08 PM
queez's Avatar
Default Re: Will a InlinePro manifold and Tial 38mm w/g clear the hood on a 00 Civic SI? (9psiTurboSI)
you shouldnt have any problems
Old 06-01-2004, 04:23 PM
99B16Si's Avatar
it will hit your hood barely if u use the fitting on the top of the wastegate that tial provides. if u leave it open it will clear
Old 06-01-2004, 04:47 PM
Default Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">it will hit your hood barely if u use the fitting on the top of the wastegate that tial provides. if u leave it open it will clear</TD></TR></TABLE>
Exactly, what I wanted to know
Old 06-02-2004, 05:51 PM
queez's Avatar
Default Re: (9psiTurboSI)
i'm using a tial wg and inline pro manifold with the top port in, and it doesnt hit
Old 06-02-2004, 07:21 PM
99B16Si's Avatar
is an si???
maybe mine hits because i have the 1.8 block with the 1/4" higher deck height
Old 06-03-2004, 09:28 AM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">I'm not going to be using the top port for anything and I wanted to know if I'll have any fitment issues clearing the hood???</TD></TR></TABLE>
its real close...I put an indention on the (not sure on the correct terminology) rib on the hood, just be safe. Or you can cut the rib that comes real close in contact with the WG
Old 06-03-2004, 09:59 AM
IN VTEC's Avatar
Tape a piece of play-doh on the section of hood and close the hood. If there's no impression, then drive around with it. The engine rocking back and forth might be an issue, especially if you have stock mounts and no mount inserts.
Old 06-03-2004, 10:15 AM
bluebullet's Avatar
barely touches on mine, not a problem though at all.
Old 06-03-2004, 10:18 AM
queez's Avatar
Default Re: (bluebullet)
yup 00 si with b16
Old 06-18-2004, 07:59 PM
2KCivicDude's Avatar
if i have a b18c1 in a crx with a inlinepro manifold and a 38mm tial w/g would i have any problems with the hood clarence???? please answer ASAP
Old 06-19-2004, 02:34 PM
powerls's Avatar
if you are worried about the clearance of a tial 38mm w/g, just get a turbosmart ultragate 35mm. It has smaller over all dimensions and it flows 20% more than the tial 38mm. Plus the ultragate is made of 253ma steel and it is investment cast, so it will never corrode. Besides, Inline Pro uses the ultragate w/ their manifold
Old 06-19-2004, 02:38 PM
mrbsponge's Avatar
i have a 2000 si with the drag manifold and a tial and mine hits, im using the top nut for the boost controller
Old 06-19-2004, 04:33 PM
BlueSi2k's Avatar
Default Re: (mrbsponge)
I have a 00 si with the inline pro and tial 35mm and mine hits with the top piece on. It made a little dent in the part under the hood from the engine moving but it wont be visible from the top.
Old 06-19-2004, 05:03 PM
Boosted Chemist's Avatar
Default Re: (Crx Dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Dude &raquo;</TD></TR><TR><TD CLASS="quote">if i have a b18c1 in a crx with a inlinepro manifold and a 38mm tial w/g would i have any problems with the hood clarence???? please answer ASAP</TD></TR></TABLE>
yeah it hits, i got a b16a wiht inline pro (16s are shorter than b18c1) and it hits
Old 06-19-2004, 05:40 PM
JSpin's Avatar
Default Re: (Mad Chemist)
a good friend of mine has a b16 using the inline pro/tial combo, and he doesn't have problems. i know when he did the swap, he cut some of the skeleton out of the hood, so that might be the ticket......
Old 06-19-2004, 09:14 PM
Default Re: (JSpin)
yea that is what i was thinking but how much would it hit? i have a project crx and all i need is my turbo kit. soo waht king of wastegate should i use for the most clarence for the crx hood.
Old 06-20-2004, 08:03 AM
powerls's Avatar
like I said, the turbosmart ultragate has smaller dimensions and will provide you will more than enough clearance for your application. Not only does it provide more clearance, the ultragate is a better w/g
neoc03
06-23-2008 07:20 PM
flarinpnoi
04-28-2004 09:41 AM
Muckman
02-22-2004 08:13 PM
ImAcracker
01-01-2004 09:24 PM
Quick Reply: Will a InlinePro manifold and Tial 38mm w/g clear the hood on a 00 Civic SI?
