no boost until 6k
Old Sep 28, 2005 | 03:07 PM
weak_sauce's Avatar
Default no boost until 6k
i have a 98 integra gsr, with the greddy kit, blox intake manifold and ctr cams, no exhuast/pipings (stock pipe and muffler), no spark plugs (stock), no injectors (stock), the boost is at 5 psi, when i floor it, i dont get boost until 6k rpm. What could be the problem?
Old Sep 28, 2005 | 04:03 PM
TheShodan's Avatar
Moderator
Default Re: no boost until 6k (weak_sauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weak_sauce &raquo;</TD></TR><TR><TD CLASS="quote">i have a 98 integra gsr, with the greddy kit, blox intake manifold and ctr cams, no exhuast/pipings (stock pipe and muffler), no spark plugs (stock), no injectors (stock), the boost is at 5 psi, when i floor it, i dont get boost until 6k rpm. What could be the problem?</TD></TR></TABLE>
Whoa, hold the phone..... You got a Greddy kit, without the injectors, stock heat range plugs, no blue box or e-manage, and you're wondering what is wrong?
Somethings going to go real soon.
Old Sep 28, 2005 | 04:16 PM
mstolars's Avatar
Default Re: no boost until 6k (TheShodan)
Are you at least running an FMU? I'd have to assume yes. Get an exhaust or run open downpipe, that will help a lot, but you will probably spike boost with open downpipe. Also, go get some colder plugs, cheap safegaurd from detonation, then start working on a better fuel system. If you wanna go real cheap get a test pipe or gut the cat, might free up some exhaust restriction helping boost come in sooner.
Old Sep 28, 2005 | 05:00 PM
project dc2's Avatar
fat exhuast leak or clogged cat.
i woudlnt boost on THAT fuel management
greddy stopped giving out FMU's in like 1996.
David_Dc2
Jul 2, 2007 06:12 PM
weak_sauce
Oct 1, 2005 01:13 PM
Turbo(less)DB8
Mar 12, 2005 06:49 PM
BDTURBO
Nov 11, 2004 05:16 PM
Snail Tuning
May 15, 2004 07:42 PM
