injector dutie
Old Sep 26, 2005 | 01:53 PM
boost'dsiR's Avatar
Default injector dutie
hi i have a single cam turbo on hondata and a avcr and everytime i full throttle 2nd or 3rd gear by the time vtec engage at 5300 it hits 100 percent injector dutie i have 660 injectyors on them right now and it is tuned to 7 pounds theres no engine check either. can anyone tell me whats wrong in this picture
Old Sep 26, 2005 | 02:39 PM
mamaboy's Avatar
Default Re: injector dutie (boost'dsiR)
whats your afr?
Old Sep 26, 2005 | 02:55 PM
boost'dsiR's Avatar
Default Re: injector dutie (mamaboy)
when it was on the dyno 12 maybe a tad bit higher but when looking at avcr its says its throwing in all the gas 100 injector duty
Old Sep 26, 2005 | 04:43 PM
TurboCoop's Avatar
Theres no way your injectors are at 100% duty if your A/F is good and you have 660's. The AVCR is wrong, I never used an AVCR but is there a way to change the injector size on it? Did you see what Hondata said the duty cycle was when you tuned it, that will tell you the real %.
Old Sep 26, 2005 | 04:57 PM
1turbodc2's Avatar
agreed, your injectors would fail, and if u have 660s u should be more then fine, i am getting some 450cc injectors for my trubo gsr, and pumping my boost up to 10 so i doubt u are maxing out your injectors
Old Sep 26, 2005 | 05:04 PM
TurboCoop's Avatar
Default Re: (gssr)
I was maxing out my 450s at about 13psi while tuning, on my LS/Vtec. I need some 750's.
Old Sep 28, 2005 | 09:15 AM
boost'dsiR's Avatar
Default Re: (TurboCoop)
hmmm thanks guys. im gonna check the percentage on the hondata . thanks for the info .ooo does vtec work better for u guys at low rpm or high?
Old Sep 28, 2005 | 12:22 PM
TurboCoop's Avatar
Default Re: (boost'dsiR)
With mine set at 5500 power dropped off as soon as it kicked in, looked like about 10 hp for a second, but when we set it at 6000 it was a perfect upward slope, not dipping at all anywhere-- here it is set @ 6000: https://honda-tech.com/zerothread?id=1373014
Old Sep 28, 2005 | 01:12 PM
boost'dsiR's Avatar
THANKS ill try that
hyboost
Engine Management and Tuning
Apr 29, 2011 05:09 AM
mafay2
Nov 12, 2004 08:24 AM
Nextelbuddy
Jul 7, 2003 07:58 PM
teg92
Dec 30, 2002 08:14 PM
kaneda3
Dec 30, 2002 12:18 PM
