Any of you using the BBK intake manifold??
Old Sep 28, 2005 | 10:34 AM
f1 vtec's Avatar
Default Any of you using the BBK intake manifold??
Hi just wanted to know if any of you are using a BBK intake manifold on your boosted honda's (on a B18C )or know of anyone using it. If so please tell me what Throttle body you are using??
Im having trouble matching the 70mm STR TB with it, im wondering if i can only use the BBK TB with it.
I thought id give it a try and see how well it does.
Old Sep 28, 2005 | 12:06 PM
f1 vtec's Avatar
Default Re: Any of you using the BBK intake manifold?? (f1 vtec)
Bump some1 must know some1 with a BBK
Old Sep 28, 2005 | 12:29 PM
BoOstedEM1's Avatar
Contact the people you got the manifold from ..or the company that makes it. Then contact str. and ask why isnt fitting.
Old Sep 28, 2005 | 01:29 PM
mstolars's Avatar
Default Re: Any of you using the BBK intake manifold?? (BoOstedEM1)
I almost bought that manifold, but wasn't sure if all the stock sensors will fit on it like the IACV. Also, it should fit any TB that fits on your stock intake manifold, since you are supposed to be able to use the stock TB on the BBK, right?
Old Sep 29, 2005 | 05:55 AM
f1 vtec's Avatar
Default Re: Any of you using the BBK intake manifold?? (mstolars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstolars &raquo;</TD></TR><TR><TD CLASS="quote">I almost bought that manifold, but wasn't sure if all the stock sensors will fit on it like the IACV. Also, it should fit any TB that fits on your stock intake manifold, since you are supposed to be able to use the stock TB on the BBK, right?
well the stock throttle body wouldnt fit on the BBK?
any info, anyone
Old Sep 29, 2005 | 06:11 AM
JSpin's Avatar
who makes bbk products? it looks a lot like the JG manifold.
nevermind.........SEARCH comes through again: BBK = JG manifold
Old Sep 29, 2005 | 06:14 AM
f1 vtec's Avatar
Default Re: Any of you using the BBK intake manifold?? (JSpin)
It looks as tho very few ppl have tried it.To tell u the truth it does look Good the only thing that has given me probs on it matching the TB apart from that its I tried searching and very little info comes up.
All i need to know is if anyone has a BBK intake mani working on there car what TB do they have
Old Sep 29, 2005 | 06:16 AM
JSpin's Avatar
read my previous post.........a quick search will tell you that like, 1943875 people have the edelbrock manifold. base your research off of that, and you'll get your answer.
Old Sep 29, 2005 | 06:24 AM
f1 vtec's Avatar
Its not EXACTLY like the edelbrock, some parts are different such as the Edelbrock has a 65mm opening when a BBK has a 70mm TB opening. and its that, that i have a problem with.
Thanks for your advice tho
Old Sep 29, 2005 | 11:50 AM
f1 vtec's Avatar
bump for info
Old Sep 29, 2005 | 11:56 AM
project dc2's Avatar
a customer of mine is prolly gonna be instalilng his soon.
lookin at it in person its VERY clean finished and looks like a greatmanifold. i think he may be installing it tonight so ill try to post up results.
Old Sep 29, 2005 | 11:58 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
any pics of the problem?
Old Sep 29, 2005 | 12:08 PM
f1 vtec's Avatar
Default Re: Any of you using the BBK intake manifold?? (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">a customer of mine is prolly gonna be instalilng his soon.
lookin at it in person its VERY clean finished and looks like a greatmanifold. i think he may be installing it tonight so ill try to post up results. </TD></TR></TABLE>
Yea thanks.. the only thing i had to modify was the throttle cable
any idea what TB he is gonna use with it?
It is a very nice manifold. nicely finished like u said
the problem im having is getting the port that leads to the IACV on the Intake manifold to match with the port on the STR TB. when attached together the Port on the TB is ina different position causing the entryport on the manifold to be blocked, and I THINK that is not letting me idle properley.
Old Sep 30, 2005 | 07:16 AM
f1 vtec's Avatar
up
Old Sep 30, 2005 | 07:40 AM
hr has an RPM service 70MM TB but he still hastn installed it
Old Sep 30, 2005 | 08:52 AM
ValleySyder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1 vtec &raquo;</TD></TR><TR><TD CLASS="quote">
any info, anyone</TD></TR></TABLE>
yes they are exactly a replica of JG Victor X
I run the JG Victor X on my 84mm GSR Turbo and my little bro runs the BBK Manifold on his B20Vtec Turbo and we have both had side by side comparisson of the manifolds when it wasnt installed in the car..and yet i cant not tell a difference between the two .. as far as stock TB on the BBK , we dont have an answer .. he is running the 70mm BBK TB which is a great throttle body for the prices asked from ebay and HT sponsored vendors
Old Oct 1, 2005 | 06:33 AM
f1 vtec's Avatar
Default Re: Any of you using the BBK intake manifold?? (ValleySyder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ValleySyder &raquo;</TD></TR><TR><TD CLASS="quote">
he is running the 70mm BBK TB which is a great throttle body for the prices asked from ebay and HT sponsored vendors</TD></TR></TABLE>
I think that maybe my problem the STR TB is not matching with theBBK intake mani, i could either get a BBK TB or get another inatke manifold
Old Oct 3, 2005 | 06:17 AM
f1 vtec's Avatar
bump for more info, anyone using a BBK intake manifold what TB are u using
SilverWarrior
Welding / Fabrication
Oct 19, 2007 12:27 PM
Shizznaz
Jun 19, 2005 10:52 PM
typer906
Dec 21, 2001 01:00 PM
migo
Aug 3, 2001 01:01 PM
