borg warner gm-8 useable for a high hp solid deck b16a?
Old Sep 27, 2005 | 03:37 PM
ccfab's Avatar
Default borg warner gm-8 useable for a high hp solid deck b16a?
well guys, i am trying to make 400whp for under 1500 dollars. so far im almost done and have spent not even a thousand.
i picked up amint borg warner ihi gm-8 last night with no shaft play for 30 bucks from a guy who doesnt know much about turbos bviously. my question is, when aprox. will this beast spool. ive had a sc61 and 60 trim on my gsr and am wondering if this turbo will display simila traits.
plans for motor are 20-25 psi
obd1 b16a filled block longblock - 400 bucks
.10 over srp pistons - 200 bucks
eagle rods traded for them
b.w gm-8 30 bucks
dsm bov freebie
til 38mm traded for
so yeah, its coming together nicely
motor is all there just needs to be assmbled.
just looking to see if anyone has any experience running one of these.
thanks
Old Sep 27, 2005 | 04:48 PM
ccfab's Avatar
Default Re: borg warner gm-8 useable for a high hp solid deck b16a? (ccfab)
anyone??
Old Sep 27, 2005 | 05:15 PM
Jockobo's Avatar
i have one of those...have yet to put it on and its pretty hard to find info about it anywhere...i would like some info too
Old Sep 27, 2005 | 05:29 PM
bubs's Avatar
I have a borg-warner gm-5, but I'm not sure how it compares to the gm-8. Mine has a .63 a/r compressor and .70 a/r turbine and starts building boost at about 2800-3000 on my h22. It has worked well for me so far.
Old Sep 27, 2005 | 09:07 PM
ccfab's Avatar
Default Re: (bubs)
i know the gm-4 and gm-5 are earlier versions of the gm-8
the gm-8 is the latest version of the turbo used on the 6.5l chevy diesels. i couldnt find specs though.
i know its a .70 compressor, but i was unsure on the .ex housing a/r.. any ideas what type of hp they will support?
a 3k spool on a h22a will net me prob 4500 to 5k spool on a built b16a... thats acceptable
Old Sep 28, 2005 | 03:19 AM
bubs's Avatar
I had my numbers way off on the a/r for the gm-5 it's a .70 compressor and a .60 turbine. I was trying to go off memory
Not sure, but I would think that the gm-8 might be able to support up to 475-500hp? I know that mine keeps pulling hard till red-line.
I bought mine from this website: http://blaastperformance.com/. The guy that I ordered from seemed to know quite a bit about the borg's, so you might be able to email him and see if he has any information on it.
Old Sep 28, 2005 | 05:55 PM
ccfab's Avatar
Default Re: (bubs)
lil pc of it on the turbo mani i made......
Old Sep 28, 2005 | 08:01 PM
Jockobo's Avatar
Default Re: (ccfab)
have you figured out the downpipe side? im still at a lost there...
Old Sep 29, 2005 | 12:09 AM
stealthmode62's Avatar
Default Re: (Jockobo)
ccfab?
Spending money on honda's is worthless, Josh.
Old Sep 29, 2005 | 03:15 AM
bubs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jockobo &raquo;</TD></TR><TR><TD CLASS="quote">have you figured out the downpipe side? im still at a lost there...</TD></TR></TABLE>
The website I listed above sells the 4 bolt flanges that fit them.
Old Sep 29, 2005 | 06:02 AM
Jockobo's Avatar
Default Re: (bubs)
cool...never seen anybody make flanges for it what about the wastegate section...does that flange protrude in a little to cover it completely??? i notice it sticks in a little...
Modified by Jockobo at 2:21 PM 9/29/2005
Old Sep 29, 2005 | 07:13 AM
bubs's Avatar
The flanges are flat. You'll probably want to take it to a machine shop to have the outer edge machined down to match the height of the WG hole.
Edit: I meant take the turbine housing to the machine shop and have it machined down so it's level with the WG hole.
Modified by bubs at 3:37 PM 9/29/2005
Old Sep 29, 2005 | 11:19 AM
D-t's Avatar
D-t
Default Re: (bubs)
400whp for 1500 bucks. NIICE
Good Luck Hrex
Old Sep 29, 2005 | 11:21 AM
Jockobo's Avatar
Default Re: (bubs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubs &raquo;</TD></TR><TR><TD CLASS="quote">The flanges are flat. You'll probably want to take it to a machine shop to have the outer edge machined down to match the height of the WG hole.</TD></TR></TABLE>
oic...good find though...the only other place that had that style flange was selling it for 75 bucks im gonna take that picture off now cause its too big...
Old Sep 29, 2005 | 11:23 AM
Joseph Davis's Avatar
Sup, hotsex.
Old GTP38's on the earlier Chebby diesels were good for 450 whp. I'm sure that pile of crap is commeasurate.
Old Sep 29, 2005 | 01:17 PM
ccfab's Avatar
Default Re: borg warner gm-8 useable for a high hp solid deck b16a? (J. Davis)
why buy anything when you have the tools and skill to make it urself. im filling the wg hole and making a external blockoff flange myself.
having a plasma cutter makes everything easy.
Old Sep 29, 2005 | 01:54 PM
redzcstandardhatch's Avatar
something different
does that thing have a regular T3 flange?
Old Sep 30, 2005 | 04:58 PM
ccfab's Avatar
Default Re: (redzcstandardhatch)
yes
rdeezy78
Sep 11, 2006 05:30 PM
kenepo_vtec
Oct 3, 2004 09:19 AM
hellaqwik21
Sep 25, 2004 12:46 PM
turborex
Nov 10, 2002 03:24 PM
