Fuel system
Old Sep 30, 2005 | 06:34 AM
done's Avatar
Default Fuel system
Right now im running:
Aem FPR
Aem Fuel rail
Walbro 255hp intank
OEM filter
I want to get rid of the oem filter, can i just get an aftermarket aeromotive or something? and also how can i attach a gauge to the fuel rail??
Old Sep 30, 2005 | 06:48 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Fuel system (Jordo@KAP)
You can run the aeromotive filter if you have braided lines to the tank. Or convert the hard feed line to a braided line with a clamp and go from there.
AEM does make a filter that mount's in the stock location and uses the stock lines and fittings.
The aem rail only has one port so if you are running the stock mounted FPR then you cant mount the gauge on the rail unless you drill and tap it.
You can get an -an in-line fitting to go right before the rail that you can screw the gauge into so you can see the pressure.
Old Sep 30, 2005 | 07:27 AM
G
sh!t happens.
Get a aem fuel filter. You can get a FPR that doesn't mount on the fuel rail and put the guage where the fpr was or put a guage on top of the fuel filter. Take the screw out of the top of the fuel filter and buy a gauge that takes it's place. I had mine like that for 2 years. Now i have all braided lines.
Old Sep 30, 2005 | 07:41 AM
TurboJesse
Guest
Posts: n/a
Default Re: Fuel system (G"UNIT)
I ran an aeromotive...cut the line from the tank to the filter, flared it, used a flare fitting and then ran a braided line to the filter...pretty simple
tinctorus
Dec 11, 2010 09:18 AM
RACEPAK
Dec 5, 2006 12:38 AM
Tegra
Jan 8, 2003 11:14 AM
DubyaAye
Jan 7, 2003 10:33 PM
