Built Turboed GSR
Old Sep 27, 2005 | 07:33 PM
JLHDOHC's Avatar
Default Built Turboed GSR
Rebuilding for some higher power out of my 84mm Sleeved GSR block not saying it was bad but recently discovered a melted piston on number 4 it actually was getting worse from 1-4. 4 was the worst though, I will be posting pics of it tomarrow. Now were rebuilding I bought the block put togehter all ready. Now I will have 98dc2r put it together local honda-tech buddy. What bearings are good to use on high boosted motor's I have heard O.E.M but even on high reving and boosted blocks........Would lower the compression of the piston be a must if i wanted more boost I was running 9 to 1
Modified by JLHDOHC at 8:46 PM 9/27/2005
Old Sep 27, 2005 | 07:41 PM
vaporboy12's Avatar
Default Re: Built Turboed GSR (JLHDOHC)
i run oem bearing on my 500whp motor reving to 9800 compression is 9:1
Old Sep 27, 2005 | 08:13 PM
JLHDOHC's Avatar
Default Re: Built Turboed GSR (vaporboy12)
Thats crazy to think that they hold up to that. When the bearingsare in the factory motors they are not even seeing close to that power.
ruffrhyder
Engine Machining & Assembly
22
Oct 8, 2019 01:02 PM
ben.s
Sep 1, 2015 05:31 AM
Boosted_MRCSI
Mar 20, 2007 11:39 AM
DeadVet
Apr 26, 2005 11:51 AM
natesown
Jul 24, 2004 11:43 PM
