help..turbo for a b20 non vtec.
Old Sep 26, 2005 | 06:46 PM
hi-Powered's Avatar
Default help..turbo for a b20 non vtec.
i need a turbo for my b20 non vtec crx.
just want to make at least 250-300 whp.
here's my setup right now.
crower stage 2 cams
ss valves, dual valve springs
stock sleeves
wiseco 11:1 piston
eagle rods
stock injectors.
and it ran 12.9 sec st @ 1/4 mile.
Old Sep 26, 2005 | 07:00 PM
jfoster's Avatar
Default Re: help..turbo for a b20 non vtec. (hi-Powered)
B20 sleeves can crack at the mention of the word turbo .... and 11.1 comp too
Turboing that motor would be a very delicate process ....
I chose a Precision SC34 57trim .63 AR for my LS-T
Good luck
Old Sep 26, 2005 | 07:01 PM
ek9vboi2's Avatar
11:1 compression is kind of well....HIGH! I would change that out unless ur a gangster
By the way I don't think the stock sleeves would like that high compression + a snail no matter what size. Bring the compression down to aroun 9:1 or so to be safe.
A t3/t04e should have no problem making that amount of power with a b20 non vtec. Since you have a semi built head and a semi built block. Cams might be a little too much or too agressive, but then again I dunno shyte about cams.
Upgrade injectors as well...maybe to 550cc. You can easy max 440cc.
My stock b20b (compression 8:8) makes 250whp and 225tq (greddy sp exhaust) @ 11lbs. You should have no problems making 300hp w/ a little work.
Old Sep 26, 2005 | 07:03 PM
ek9vboi2's Avatar
TUNING IS KEY! Main reason why so many people blow b20s is because of the lack of tuning and care for the motor.
I have been boosted for over a year and constantly beat on my car...redline...the whole 9. But then again I had my car tuned by Mase on Hondata.
ekcoupeh22
Sep 23, 2010 10:03 AM
iamthefollower
Jan 29, 2010 08:58 AM
sontdawg
23
Aug 6, 2007 05:56 PM
JDM97EK
Oct 28, 2006 09:12 PM
99EletronblueSI
Oct 20, 2004 07:46 AM
