How much does a drop in static compression affect a tune?
Old Sep 30, 2005 | 05:21 PM
Dr Pooface's Avatar
Default How much does a drop in static compression affect a tune?
I'm building my block, dropping compression from 10.5:1 to 9:1. My problem is that I'll need to break in my new clutch before I retune. How will the drop in compression affect my current tune? I'm guessing that since I'll be running the same boost and fuel trim nothing will change at all as far as a/f ratios are concerned.
Old Sep 30, 2005 | 05:41 PM
turboEGhatch's Avatar
Default Re: How much does a drop in static compression affect a tune? (Dr Pooface)
the 9:1 motor will take a good bit more timing.
Old Sep 30, 2005 | 06:51 PM
Dr Pooface's Avatar
Default Re: How much does a drop in static compression affect a tune? (turboEGhatch)
Oh I know it will take more timing, it'll also take a hell of a lot more boost. My question is will the a/f's be the same, and if they will be different will they be richer or leaner.
Old Oct 1, 2005 | 12:28 PM
Dr Pooface's Avatar
bump for an answer
Old Oct 1, 2005 | 08:58 PM
ccivic's Avatar
It'll change. I'd atleast get it slightly tuned or something. Just make sure you don't run rich and wash your rings out.
Old Oct 4, 2005 | 07:15 AM
Dr Pooface's Avatar
Default Re: How much does a drop in static compression affect a tune? (ccivic)
bump for a definitive answer.
Old Oct 4, 2005 | 07:26 AM
93turbo16's Avatar
it WILL change. If you leave an O2 sensor enabled, it would probably be enough to take the car out and drive it with no problems.
Old Oct 4, 2005 | 08:24 AM
Dr Pooface's Avatar
Default Re: (93turbo16)
richer or leaner?
Old Oct 4, 2005 | 08:26 AM
93turbo16's Avatar
Honestly it all depends, but I would say it SHOULD go richer.
the_yblegal
Engine Management and Tuning
Jun 2, 2014 04:50 PM
peakboosth22
Jun 20, 2006 08:55 AM
paopao
Jan 13, 2006 09:42 PM
oilguzzler
Nov 17, 2005 07:52 PM
careawholelot
13
Aug 20, 2003 08:02 PM
