Built Gsr
Old Sep 30, 2005 | 03:07 PM
JLHDOHC's Avatar
Default Help Built Gsr
Just took my darton sleeved GSR block in to the machine shop today the sleeves are 84mm the guy wants to know how much I want honed, suggested boreing to 84.5mm or even 85mm bad thing is, I starting to take this motor apart just to replace head gasket bought a new cometic head gasket 84mm.Once apart found number 4 piston melted a little. Now rebuilding, If i go ahead and have him hone it out a little possibly 20 over he said it wont even need that much, will I still be able to use the 84mm head gasket cause if not I wanna bore the sleeves out to 84.5 possibly 85mm would that be bad to do on turboed motor....Whats a good Head gasket for HIGH BOOST Please post opinions
Modified by JLHDOHC at 4:35 PM 9/30/2005
Old Sep 30, 2005 | 03:37 PM
JLHDOHC's Avatar
Default Re: Help Built Gsr (JLHDOHC)
What about compression ratio on pistons i currently have the old Je 9:0:1 if i go up into some higher boost levels should i lower it
Old Sep 30, 2005 | 04:37 PM
Ben Huynh's Avatar
You can still use the 84mm HG if you go 84.5mm. If you go 85mm, you'll need an 85mm HG. We have them in stock if you need one. As for CR, stick with 9:1.
Old Sep 30, 2005 | 06:30 PM
JLHDOHC's Avatar
Default Re: Help Built Gsr (ben@importparts.com)
Thanks that helps out to know that i dont have to get a new HG..
Old Sep 30, 2005 | 09:55 PM
Ben Huynh's Avatar
Anytime.
ONESICKFERIO
Feb 11, 2010 06:28 PM
Kris's turbo
Jun 6, 2008 07:40 PM
fergy016
17
Jun 17, 2007 08:29 AM
ochsy03
Apr 20, 2005 06:40 PM
Ltech
May 17, 2002 04:05 AM
