headgasket or what?
Old Oct 1, 2005 | 12:40 AM
Timmay's Avatar
Default headgasket or what?
stock z6 on boost
im pusing a little coolant in the resivour, and my temp gauge goes up a bit
i do pulls in boost and sometimes it wont go up and sometimes it will
i have new oem thermostat, tried 3 rad. caps, coolant is bled out , all grounds are good and ive tried different sensors
comp is 175-180 all 1-4
havent done leakdown just yet, im almost thinking headgasket but its not blowing smoke and temp only goes up every once and a while
Old Oct 1, 2005 | 02:17 AM
rmcdaniels's Avatar
Default Re: headgasket or what? (Timmay)
Head gasket, mine did that a few times before I got it fixed right. It leaked combustion chamber gases into the water jacket under boost, the hot gases going by the coolant temp sensor caused the temp gauge to spike, and they blew some coolant out of the reservoir. A new head gasket would last less than a month, but one of the Cometic HP gaskets lasted for 9 months, it's got a slightly thicker sealing ring around the tops of the cylinders. I eventually pulled the motor and got the block decked to finally fix it, but the HP gasket worked well for me in the interim.
Old Oct 1, 2005 | 02:26 AM
Timmay's Avatar
Default Re: headgasket or what? (rmcdaniels)
yea i was thinking that, but sometimes under boost it doesnt do it
i have a new oem gasket ready to go on, with a little copper spray
Old Oct 1, 2005 | 06:16 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">yea i was thinking that, but sometimes under boost it doesnt do it
i have a new oem gasket ready to go on, with a little copper spray</TD></TR></TABLE>
1. it could be that the radiator is just too small. or maybe getting "heat soaked" from your downpipe or something..
2. air bubbles....
3. and lastly the headgasket.
Old Oct 1, 2005 | 07:20 AM
CoreyR's Avatar
Default Re: headgasket or what? (Dturbocivic)
your probably getting headlift if your on stock head bolts. single cams tend to do that from what ive seen. it would be a good idea to spend $90 on some ARP headstuds and a new headgasket.
Old Oct 1, 2005 | 08:10 AM
rmcdaniels's Avatar
Default Re: headgasket or what? (CoreyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">your probably getting headlift if your on stock head bolts. single cams tend to do that from what ive seen. it would be a good idea to spend $90 on some ARP headstuds and a new headgasket.</TD></TR></TABLE>
I hadn't thought about that, but it makes sense. My motor was a B16 with ARP studs.
Old Oct 1, 2005 | 11:18 AM
Timmay's Avatar
i have arps
im wondering if my radaitor isnt flowing enough or where the cap seals its letting coolant push by when hot then getting air into it
i have a better fan than stock to
Old Oct 1, 2005 | 11:40 AM
SOHC_MShue's Avatar
I've blown a number of headgaskets on my sohc even with arp's with the same exact symptoms you are describing. Its the headgasket i'm 99% sure.
Old Oct 1, 2005 | 11:50 AM
Timmay's Avatar
Default Re: headgasket or what? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">I've blown a number of headgaskets on my sohc even with arp's with the same exact symptoms you are describing. Its the headgasket i'm 99% sure.</TD></TR></TABLE>
yea thats how my last setup was but the temp doesnt go up everytime i boost like it has before
Old Oct 1, 2005 | 12:07 PM
SOHC_MShue's Avatar
It might start getting worse. No way of telling yet.
Old Oct 1, 2005 | 12:18 PM
Timmay's Avatar
another thing is my rad cap was loose so i squeezed the tabs a little and it doesnt seem to push much coolant but still gets warm sometimes
doing the headgasket isnt a problem, 1 hr worth of work i just dont want to replace it yet if not needed
Old Oct 1, 2005 | 12:44 PM
SOHC_MShue's Avatar
Yea its a pain in the *** when changing the gasket gets to be a regular thing you do every 3500 miles
Old Oct 1, 2005 | 01:03 PM
Timmay's Avatar
well if anyone else has ideas of something other than the headgasket
post it up
95% that is my prob though
krc91987
Jun 28, 2015 03:51 AM
20civic01
Honda Civic (2001 - 2005)
17
Feb 23, 2014 06:40 PM
boostedNOTHARDLY
Dec 4, 2007 07:27 PM
gsrvtec2
Oct 15, 2005 05:40 PM
Gsr_Hybrid_theory
Dec 20, 2004 07:50 PM
