engine managment E-MAN
Old Sep 27, 2005 | 02:11 PM
ttaplin's Avatar
Default engine managment E-MAN
i need engine manegment for and obd II civic and i dont wanna go FMU so what else is there for cheap or anything
Old Sep 27, 2005 | 02:15 PM
SlowB16si's Avatar
Default Re: engine managment E-MAN (ttaplin)
Get a chipped OBD-I ECU with uberdata or crome. They are like 150, then buy an OBDII - OBDI conversion harness. then tune it or get it tuned by someone asap, also you will need injectors im sure
Old Sep 27, 2005 | 02:54 PM
1turbodc2's Avatar
agreed, i am running a chipped p72 tunned with crome pro and it works great!
Old Sep 27, 2005 | 04:19 PM
ttaplin's Avatar
what i fi just buy greddy eman will that work
Old Sep 27, 2005 | 04:29 PM
Soccerking3000's Avatar
Default Re: (ttaplin)
the emanage is a glorified v-afc hack, i personally would never use it, your better going with uber or chrome if you want something cheap, then you can take that extra cash you saved and by a wideband to tune with
Old Sep 27, 2005 | 04:49 PM
1turbodc2's Avatar
agreed the Emange is the biggest POS stay as far a way from that thing as possible, and also u don't want to cheez ball your engine mangement that is how motors blow up, that and shitty tunning
Old Sep 27, 2005 | 04:54 PM
SlowB16si's Avatar
Default Re: (gssr)
If you don't mind me asking, whats your setup and power goals?
Old Sep 28, 2005 | 05:19 PM
ttaplin's Avatar
im goign for 200whp with type s bov and a garret t3 bb turbo and spearco fmic and most likley uberdata with a obdI conversion
Old Sep 28, 2005 | 05:46 PM
PM-Performance's Avatar
In the Honda world there are too many other things on the market that the Emanage isnt top of the list.
However Emanage seems to be working in the Supra comunity well. I have the new Emanage Ultimate I am installing in mine now.
10x better then the old one. Its a real tuning tool now instead of a signal hacker
Old Sep 28, 2005 | 07:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ttaplin &raquo;</TD></TR><TR><TD CLASS="quote">im goign for 200whp with type s bov and a garret t3 bb turbo and spearco fmic and most likley uberdata with a obdI conversion</TD></TR></TABLE>
ball bearing t3? i thought only the gtxxR series was ball bearing, and until recently they just made the center sections in the 360 degree thrust bearing, or did i miss something? Uberdata is awesome i love it and made good power. Its very user friendly and easily configured for a beginner
Old Sep 28, 2005 | 07:42 PM
TheShodan's Avatar
Moderator
Default Re: (gssr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gssr &raquo;</TD></TR><TR><TD CLASS="quote">agreed the Emange is the biggest POS stay as far a way from that thing as possible, and also u don't want to cheez ball your engine mangement that is how motors blow up, that and shitty tunning</TD></TR></TABLE>
Have you ever used it? It sounds like you either didn't know what you were doing, or didn't have a tuner who knew how to use it. I just noticed the hostility towards it.
Old Sep 28, 2005 | 07:58 PM
tfnaaf's Avatar
Default Re: (TheShodan)
Im using E-manage and works FLAWLESSLY! to all the nay sayers, they just jumping on the wagon like everyone else. And its a FAR cry from a v-afc
Old Sep 28, 2005 | 08:13 PM
jayswift's Avatar
Default Re: (tfnaaf)
i had no complaints either when i was running the emanage. the guy that tuned mine really knew what he was doing and my car ran great.
Old Sep 28, 2005 | 09:58 PM
Tony the Tiger's Avatar
Default Re: (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">the emanage is a glorified v-afc hack, i personally would never use it, your better going with uber or chrome if you want something cheap, then you can take that extra cash you saved and by a wideband to tune with</TD></TR></TABLE>
You're outdated guy...
It is not the old E-manage unit with the shitty dial ***** for fuel control only...
E-manage with injector and ignition harness and Support Tool unleashes a wide variety of tuning options. Good system IMO, but for a Honda, there are many more options available.
Old Sep 28, 2005 | 10:29 PM
Default Re: (Tony the Tiger)
i am well aware of the system, it is still a glorified hack, not saying it wont work, but even with the "advanced" features it doesnt stack up to a hondata or uberdata management. It still tricks the ecu into adding/subtracting values which i dont like, even though it may work i would rather have a system that reads the sensors and uses those direct signals for the fuel map. The emanage takes the signals and changes them so the stock ecu doesnt go ape ****. I dont like add-on type deals, just me
ohh and i would only buy an emanage for something like a nissan where the stock code isnt easily decrypted, with honda thats not the case, but as i said i dont like it...
Old Sep 29, 2005 | 04:26 AM
The New Emanage wont do that.
But if you dont like add on deals, Hondata is a similar deal.
Anyway Ill let people know my reviews on the Ultimate.
I can tell you now though there are plenty on MKIII Supras running both versions fine. Also MKIV's are loving the Ultimate now becuase it lets them get rid of the maf for a low price.
Old Sep 29, 2005 | 09:07 AM
1turbodc2's Avatar
yes i have used, and i have tunned my car myself, so i know quite well what i am doing, its not something i like but that is just my opionon take it or leave it! I have now obd1 p72 ecu that i tunned with crome pro which i like by far way more..
Old Sep 29, 2005 | 09:49 AM
Default Re: (gssr)
e-manage is a much more logical engine management for cars who ecu cant be modded as easily as honda (obd-1) ecu's, there are much better and cheaper things to use, like the new neptune rtp that is coming out rivals the s300 and is only 450 bucks, the same cost as the emanage ultimate and it has waaayyyyy more functions and features...
sasinorm01
Mar 4, 2008 02:57 PM
JmurGSR98
Jun 19, 2006 06:47 PM
zeroek
Apr 4, 2006 10:09 AM
BlingBlingCivic
Dec 9, 2004 04:50 PM
NotPhilTran
Mar 31, 2004 06:24 PM
