Dual stage boost controller and your tune?
Old May 12, 2006 | 03:34 AM
VTteg's Avatar
Default Dual stage boost controller and your tune?
If you have a daul stage boost controller on your setup, to allow you to switch from say 7 psi to 12 psi or something to that effect, how would that switch effect your fuel maps and such?
I mean, when you tune your maps, arent they only good for that particular boost level? Could someone explain how this works?
Old May 12, 2006 | 06:12 AM
playahwitgame's Avatar
Default Re: Dual stage boost controller and your tune? (VTteg)
if you get tuned to 12, everything under 12 is tuned also.
Old May 12, 2006 | 07:03 AM
VTteg's Avatar
Default Re: Dual stage boost controller and your tune? (playahwitgame)
Ah, so say you are tuning with Uber, and have your boost set at 10 psi. You burn a map for 10, but then immediatly afterwards you crank the boost back down to 6 or 7, would that cause you to run richer in the lower boost application?
Old May 12, 2006 | 08:45 AM
AbitAvenger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTteg &raquo;</TD></TR><TR><TD CLASS="quote">Ah, so say you are tuning with Uber, and have your boost set at 10 psi. You burn a map for 10, but then immediatly afterwards you crank the boost back down to 6 or 7, would that cause you to run richer in the lower boost application?</TD></TR></TABLE>No, your tuned for any psi up to your max. IE if your cruising and hit 3-4 lbs, your tuned for that, and if you go WOT and hit 10, your tuned to that too
Since the map sensor only see's 6 psi, it only gives it enough fuel to cover that.
Old May 12, 2006 | 09:24 AM
dpetro1's Avatar
Default Re: Dual stage boost controller and your tune? (AbitAvenger)
yup these guys are right on. if you tune for 10 psi you are all set for 10 an below, you will not have the corect afr and timing fom all boost levels 0-10psi. this is because our maps read MAP vs. RPM. so if you are boosting 10 psi is reads from that column but if you are only boosting 7 psi is will read from a lower column and give less fuel.
Modified by dpetro1 at 4:22 PM 5/12/2006
Old May 12, 2006 | 11:52 AM
VTteg's Avatar
Default Re: Dual stage boost controller and your tune? (dpetro1)
sweeeeeet
s2kkid
Jul 4, 2005 09:04 AM
ochsy03
Mar 24, 2005 08:53 AM
microsoft_sux
Jan 21, 2005 09:15 PM
tygsr
Jun 19, 2002 01:27 PM
