Inline Pro T3 manifold with 3" DP??? Can it be done???
The current inline Pro setup Im running has the cold side on the passenger side. I wnat to know if anyone has switched the turbo so the cold side is on the drivers side and run a 3" downpipe. The IP setup isn't bad but I would like to go 3" DP instead of the 2.5.
Anypics or advice would be appreciated. Its a T3/T4 fivebolt. My friend is custom welding the DP so I'm not asking about off the shelf DP's working.
Re: Inline Pro T3 manifold with 3" DP??? Can it be done??? (MotorMouth)
https://honda-tech.com/zerothread?id=1619722
Check out the adapter I made in that thread. If you can weld or know someone, get a 2.5" sch10 or sch40 elbow & get 2 T3 flanges, then fab up an adapter putting a 15* angle on the turbo and kicking the ex housing out.
Of course it can be done. Check out my car https://honda-tech.com/zerothread?id=1532363 Im running a Inlinepro t3 manifold, precision gt35r, and a 3inch dp. to Inlinepro for a decent manifold at a great price.
Yes, and as for reversing the turbo so cold side is on the driver side yes you can do that as well. Mine fits no prob with no A/C. I am running a Fluidyne Civic radiator and my DP
is a 2.75" (just to clear the RAD) into a 3"
Re: Inline Pro T3 manifold with 3" DP??? Can it be done??? (dcturbols)
dont do that hi profile did. the turbo more then likely wont last long as oil wont drain well otu of it. if you know a thing about manifolds, you want to keep the turbo as level as possible.
Re: Inline Pro T3 manifold with 3" DP??? Can it be done??? (wade)
Thanks for the responses guys. Especially SIKITR01-248, those pics said a thousand words. Excellent, I'm set now.
YAGGA_YA
02-11-2011 02:01 PM
cuin9sec
01-25-2006 04:51 PM
lilxvtecxpwr
12-09-2002 06:13 AM
