quaife lsd install question
Old May 11, 2006 | 03:05 PM
InfamousDC2FI's Avatar
Default quaife lsd install question
Hi I am about to install my new lsd but I am having trouble figuring out the proper way of removing the speedo gear from the original lsd.
Does anyone have any tips on removing the bearings and speedo gear? I have heard that the speedo gear can be brittle and easy to break if your not careful....
Old May 11, 2006 | 08:31 PM
Shmaa's Avatar
Default Re: quaife lsd install question (InfamousDC2FI)
https://honda-tech.com/zerothread?id=1047501
Old May 13, 2006 | 03:47 PM
Default Re: quaife lsd install question (Shmaa)
Well I got the speedo gear off with a hammer and a small peice of wood by tapping the gear while turning it after every hit......
to get the gear onto the new diff I put the ring gear in the oven for 10 minutes at 425 degrees and I put the diff in the freezor for 20 mins.....it pops right on...
check out my write up on how much bad luck ive been having with this install:
https://honda-tech.com/zerothread?id=1626891
Old May 13, 2006 | 05:19 PM
IN VTEC's Avatar
I heat it up with a torch and use the flat side of a bearing splitter to lift it off.
Old May 13, 2006 | 07:59 PM
B18C1CYA's Avatar
When I installed my Quafie lsd I used the stock GSR roller tapper bearings , I just checked the installed hight of the bearings as I was installing them on the Quafie diff, not problems what so ever diff is silent and only makes some sound while making 90 degree turns wich is nomal , for the spedo gear use a 2 jaw puller and go slow pulling it off , to reinstall it I just used a plastic hammer and seated it on that way
mach3lude
Aug 29, 2011 07:18 AM
Anotherslo1
May 25, 2005 07:42 PM
Shmaa
May 24, 2005 12:52 AM
d_mina
Oct 13, 2003 10:06 PM
PupaScoopa
Apr 8, 2003 10:01 AM
