Missing link?? Help
Old May 8, 2006 | 05:22 PM
0618turbocivic's Avatar
Default Missing link?? Help
please help, i dont know why but when i adjust the SAFC2 it will affect car but when i drive in boost for while it seems not to work anymore, and the settings dont affect the car ideal or anything . it works again when i turn off car and start back up. i cant really go into boost or safc2 seems to go off, and once im in 0 or above it feels like bogging or something... right now i have stock injectors, but i will soon be putting in dsm 450cc
My question is i been reading would a missing link help with this problem? im only running 6-10psi right now i dont have a missing link do i need one to solve this problem?? please help?
Old May 8, 2006 | 06:20 PM
kdawgy2k1's Avatar
Hey wassup... Yeah a Missing Link would help you but i had the same issues with my car and ended up cracking a ring land tryna save money and short cut...Best advice to you is get a REAL engine management system and an aftermarket MAP sensor...
Old May 8, 2006 | 06:33 PM
Default Re: (kdawgy2k1)
thanks alot, i just want to make sure that helps, should i get a missing link or a aftermarket map sensor? would either one help with the problem? if i get a 2bar or 3 bar map sensor would that solve the problem that you said you had to? which one should i do? thanks
ROCAFELLA2049
Jun 29, 2006 09:24 PM
D15Bbigred
Feb 21, 2006 07:57 AM
Treblarefils
Feb 23, 2005 11:26 AM
illestrolla247
Aug 2, 2004 09:06 AM
