Anybody use JB Weld...
Old May 11, 2006 | 08:32 PM
hondaeg8's Avatar
Default Anybody use JB Weld...
on a cast iron manifold to fix a crack before?
Old May 11, 2006 | 08:34 PM
boostismycrack's Avatar
E-thug
Default Re: Anybody use JB Weld... (hondaeg8)
i'm no rocket scientist, but it will most likely melt.
Old May 11, 2006 | 08:40 PM
hondaeg8's Avatar
yup, just read that on their site.
Old May 11, 2006 | 10:59 PM
importdude2000's Avatar
u need to heat up the cast +weld
Old May 11, 2006 | 11:26 PM
CE1's Avatar
CE1
try ducktape
Old May 12, 2006 | 12:38 AM
em1 Ziggy's Avatar
Default Re: Anybody use JB Weld... (boostedD)
u can try looking at my thread i used JB weld on my block and JB weld works wonders.. many told me its not going to hold...
https://honda-tech.com/zerothread/1598334
Old May 12, 2006 | 04:23 AM
drintegra's Avatar
JB weld on the manifold will not work. I put it on a header a while back since it was leaking bad, and after the header heated up and I took it for a long spin the jbweld just flaked off. the heat generated is too hot.
Old May 12, 2006 | 08:14 AM
hondaeg8's Avatar
Default Re: Anybody use JB Weld... (drintegra)
yeah, the exhaust mani gets too hot for jb weld, so it won't work. i took the manifold to a welding shop today and they said they can weld it with no problems.
i just didn't know if they could do it cause the manifold is cast iron.
Old May 12, 2006 | 12:30 PM
tgreaves's Avatar
I used JB Weld on my downpipe once to fill some leaks from the fact that I cant weld worth ****.. I had to reapply the jbweld like every 2-3 weeks and I didnt drive the car everyday..
Just pile it on thick and plan to add more often.. Or just get it fixed and be done with it..
GEN2 LS
Welding / Fabrication
22
May 20, 2018 06:52 AM
curtie94
Mar 24, 2011 08:56 PM
FOrSfEd
May 7, 2004 06:59 AM
15psi of fun
Oct 1, 2003 01:07 AM
glagola1
Mar 26, 2003 12:20 PM
