Is this a needed item on an h22 engine? Cooling
https://honda-tech.com/zerothread?id=1601958
Please can you look at the above thread and let me know how needed the item is? This sits at the rear of the block and seems to cool the oil via a water jacket. Im frantikly searching for a part number so I can order a replacement.
Any help would be greatly appreciated.
Im building a H22 Turbo CRX and this is the last part I require to complete the build. I sent my block off to the engine shop but this part was missing on its return.
Thanks in advance
Thanks in advance
I searched but couldnt find any useful info. I saw the odd post about correct venilation of catch cans but nothing about the part I have in mind.
The part im talking about is fed by the coolant pipe and the oil from what I can see. I guess it transfers the heat of the oil into the water which is why I assumed it was a stock oil cooler.
