Finally some dyno numbers - 424whp / 365wtq SOHC D16y8 >>
Finally had time to take the SOHC D16y8 to the dyno for some tuning. Very Happy with the results
PUMP GAS
12psi - 260whp
16psi - 315whp (low boost setting)
C16
24psi - 404whp / 335wtq (high boost setting)
27psi - 424whp / 365wtq
The car is ridiculous on the street, it breaks the tires loose in 3rd on low boost and they come loose a little in 4th on high boost.
Here is the setup
SOHC d16y8
Benson sleeved stock bore
CP 9.1 pistons
Eagle rods w/ arp2000 bolts
Mircopollished crank
OEM headgasket
ARP Headstuds
D16Y8 head
Port & Pollished
3 angle valve job
Zex 105300 cam
AEM 5 bolt gear
Suptertech springs and TI retainers
PCV system removed
Jaz catch cans
Spearco radiator w/ permacool 2950 CFM fan
Sterab Oil Cooler
Stock d16y8
OBX LSD
Action 2MS, 6 puck, 3100 lbs
8.5 lb aluminum flywheel
AutoZone axles - Lifetime Warranty
Precision sc50 .48 a/r 50 trim
Custom RamHorn manifold
Tail 38mm wastegate w/ 10 psi spring
HKS SSQ bov
JRC 8" intercooler
Custom 2.5 charge piping
Custom 3 inch downpipe
Custem dump
Custom 3 inch turbo back exhaust , manaflow muffler
P28 hondata s200 w/boost
Greddy profec b spec II
RC 750cc injectors
Aeromotive FPR
Walbro 255 fuel pump
MSD Cap , and external coil
Autometer water, oil, boost, a/f, egt gauges
Ground Control custom rates 350f/450r
Koni Yellows Full adjustable.
Omni-Power front and rear camber kits
Suspension Techniques front and rear sway
Neuspeed front upper and rear lower tiebars
Energy Suspension Inserts
Full-Race Traction bar
NRG Engine Damper
TSW Catalunya 16's on Falken Azenis RT-615
4 wheel GSR disks
Brembo slotted
Axxis Ulimate pads
Graphs hosted by igo4bmx. thanks man
platinum
Modified by platinum00 at 11:05 PM 5/9/2006
Modified by platinum00 at 11:06 PM 5/9/2006
Modified by platinum00 at 10:55 PM 8/17/2006
PUMP GAS
12psi - 260whp
C16
Here is the setup
SOHC d16y8
CP 9.1 pistons
OEM headgasket
ARP Headstuds
D16Y8 head
Port & Pollished
3 angle valve job
Zex 105300 cam
AEM 5 bolt gear
PCV system removed
Jaz catch cans
Sterab Oil Cooler
Stock d16y8
OBX LSD
HKS SSQ bov
JRC 8" intercooler
Custem dump
RC 750cc injectors
Aeromotive FPR
NRG Engine Damper
4 wheel GSR disks
Brembo slotted
Axxis Ulimate pads
platinum
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: Finally some dyno numbers - 424whp / 365wtq SOHC D16y8 >> (ladysman)
What were you revving to?
I'm surprised that a SC50 .48 a/r turbo can make THAT much power at that boost level on a SOHC!
WOW WOW and WOW !!!
Like everyone asked... what kind of dyno and could you post a graph !
Man that a lot of power for a SOHC you must be proud of that. Im also really glad for you !
Re: Finally some dyno numbers - 424whp / 365wtq SOHC D16y8 >> (platinum00)
Dyno graph is coming... i cant get my damn portal working right on the site.
i only reved to 7000, i stopped making power after that which is weird with the Zex 105300 cam.
Peak TQ is ~5600
im still running a stock ignition and a stock intake manifold. im thinking i could get 20whp more with a nice ignition and intake manifold.
i will try and get some pics and dyno graph up quickly.
platinum.
Peak TQ is ~5600
platinum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">Dyno graph is coming... i cant get my damn portal working right on the site.
Peak TQ is ~5600
platinum.</TD></TR></TABLE>
about the same at me
I have a Venom sheetmetal intake manifold for sale!!
Peak TQ is ~5600
