Nitrous Problems
Old May 11, 2006 | 03:10 PM
DirectPortEF's Avatar
Default ((((((Nitrous Problems))))))
I have a stock B18A with a ZEX Direct Port Nitrous System and I keep melting Denso 3169 Plugs and Exhaust Valves !! Open to suggestions......Thanx
Modified by DirectPortEF at 7:50 PM 5/11/2006
Old May 11, 2006 | 03:24 PM
yellowrexsi's Avatar
Default Re: Nitrous Problems (DirectPortEF)
What shot are you running?
Did you retard your timing?
What temp are your plugs, they are supposed to be cold.
Old May 11, 2006 | 03:25 PM
not tuned's Avatar
is it tuned?, is your timing retarded? how big of a shot?
Old May 11, 2006 | 03:58 PM
Default Re: Nitrous Problems (not mase tuned)
Stock Tune, Denso plugs 2 degrees colder, 150 shot with 175 fuel jet...
Old May 11, 2006 | 04:02 PM
nonvtecallmotor's Avatar
Are you running pump gas?
What kinda fuel pump? You will most likely need a bigger pump then a walbro 255. On nitrous its just doesnt pump enough fuel.
Old May 11, 2006 | 04:08 PM
Azn Kenny's Avatar
Did you pull timing any? What are the plugs gapped at?
Old May 11, 2006 | 04:18 PM
hotimportcrx's Avatar
Default Re: (LSntegra)
stock tune meaning stock ecu???? WOW you can pull that off on like a 50 shot but not a 175 shot...on a 175 shot yo really need some injecotrs a fuel pump and a tune.
Old May 11, 2006 | 04:19 PM
Default Re: (hotimportcrx)
and the reason your melting valves is because its running really lean ....creating massive heat and theres no gas to cool it......you need a tune!
Old May 11, 2006 | 05:17 PM
I ran a 100 shot on a stock ecu, stock fuel pump, pump gas, no timing retard, denso plugs gapped@ 35. Went 12.57@108 on the breaks then bumped it to 150 with a Walbro 255 and started having problems.
Old May 11, 2006 | 06:22 PM
Default Re: (DirectPortEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirectPortEF &raquo;</TD></TR><TR><TD CLASS="quote">I ran a 100 shot on a stock ecu, stock fuel pump, pump gas, no timing retard, denso plugs gapped@ 35. Went 12.57@108 on the breaks then bumped it to 150 with a Walbro 255 and started having problems. </TD></TR></TABLE>You can not spray a 150shot on pump gas. You'll need to at least run Cam2 blue maybe even more octane. You can make the car run GOOD on nitrous but, you'll need a good tune and a walbro 255 will wear out over time on that kind of shot. You will also need to pull out about 6* off timing depending on the gas. You will also need some colder plugs like 7 range and gap them at .028.
With the right tune in the car you can run realy good #'s. I tuned a Civic hb with a stock GSR on a 75 shot direct port it made 266whp and ran a 12.0 on slicks and a 12.3@115 on BFG's
Old May 12, 2006 | 02:32 PM
Default Re: (nonvtecallmotor)
What about Valvetrain, Header, Fuel Press Reg and Inline Fuel Pump?
Old May 12, 2006 | 02:52 PM
street_ruler's Avatar
you shuould not be running denso plugs. they are a no-no for nitrous. anything with that type of exposed electrode will either blow off or melt like that.
Old May 13, 2006 | 05:22 PM
Default Re: (street_ruler)
Whats the biggest shot and best time anyones ever done on an LS with BONE STOCK INTERNALS?
Old May 13, 2006 | 05:27 PM
dont listen to that nonvtec guy. he ahs no idea what hees talking about
yes you can run 150 shot on pump gas.
heres a question for you NONVTECALLMOTOR: if you cant run a 150 shot on pump gas why can you run a 50 shot on it. and for that matter why can you run boost on pump gas??
see....doesnt make any sense.
and no a walbro 255lph wont "wear out" over time. it doesnt get slower and die.
you do infact need to run an extra step larger fuel jet (atleast thats what i do) and some other ignition stuff, like colder plugs ect.
Old May 13, 2006 | 05:48 PM
quicksilver1689's Avatar
i ♥ snails
How can it be running lean when your nitrous setup supplies the extra needed fuel. If your running the correct fuel jet with the N20
Old May 14, 2006 | 05:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ruler &raquo;</TD></TR><TR><TD CLASS="quote">dont listen to that nonvtec guy. he ahs no idea what hees talking about
you do infact need to run an extra step larger fuel jet (atleast thats what i do) and some other ignition stuff, like colder plugs ect. </TD></TR></TABLE>Yea I guess I'm the dumbass. And your asking the difference in a 50 shot and a 150 shot? I guess that you have sprayed more then I have?
I think that you may need to go read the BIG nitruos tread in this section.
I think you'll learn a little something.
Old May 14, 2006 | 05:17 PM
non-VTEC's Avatar
WTF.....you have no idea what your yapping about..........throw your PC out the window.
Old May 14, 2006 | 06:11 PM
Default Re: (non-VTEC)
Whats the Best Fuel Management for Nitrous? How much does it cost? I'm OBD0
Old May 14, 2006 | 07:23 PM
hgave you ever used nitrous or just seen the fast and furious?
Old May 14, 2006 | 08:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirectPortEF &raquo;</TD></TR><TR><TD CLASS="quote">Whats the Best Fuel Management for Nitrous? How much does it cost? I'm OBD0</TD></TR></TABLE>I would get an obd1 conversion harness and use crome.
Old May 14, 2006 | 08:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ruler &raquo;</TD></TR><TR><TD CLASS="quote">hgave you ever used nitrous or just seen the fast and furious?</TD></TR></TABLE>That movie is the greatest. I've only seen it a few thousand times. WOW what a movie.
Old May 15, 2006 | 12:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ruler &raquo;</TD></TR><TR><TD CLASS="quote">hgave you ever used nitrous or just seen the fast and furious?</TD></TR></TABLE> If you stopped running your mounth and opened your eyes you can see (I ran a 100 shot on a stock ecu, stock fuel pump, pump gas, no timing retard, denso plugs gapped@ 35. Went 12.57@108 on the breaks then bumped it to 150 with a Walbro 255 and started having problems.) that I have used Nitrous and are just getting some tips before I rebuild and waste a motor! MEAT HEAD!!!!!!!!!!!!
Old May 15, 2006 | 04:21 PM
wow...meant head, insightful.
so was it DP or single fogger or what?
what solenoids were you running, what size lines, it all matters. its not just your fuel pump that is important.
Old May 15, 2006 | 04:22 PM
and i wasnt even talking to you, jackass...
and a zex wet kit is only good for 150 (from what i read) so thats probably why you had problems. the solenoids in the box arent that hi-flo. im running the older NOS brand cheaters that are good for 400 hp blasts.
keep that in mind
Old May 15, 2006 | 05:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ruler &raquo;</TD></TR><TR><TD CLASS="quote">and i wasnt even talking to you, jackass...
keep that in mind</TD></TR></TABLE>
Then Quote the person your talking,cuz your post was under mine...one asked you what you've read and I didnt ask what type of system your running. So Body Out!!!!!!!!
